60k service? 90k service? $250 for Service A?
Hi everyone. My car is nearing 60k miles. I have a local mechanic who can do my oil change for around 80- 100 bucks (using all MBenz products oil & filters). I called the dealer and asked what was performed on Service A and was told basically an oil change and that it cost $250. Is there anything else i should have my mechanic do for service A? $250 is a little steep for just an oil change for service a. Even when we had our 5 series, oil changes were only 90 at the dealer.
60k service:
The dealer stated that my fuel filter, air filter, and spark plugs need to be replaced at 60k. IS there anything else? I asked if they had a recommended service guide but he said no.
90k service:
What needs to be done on this?
Any help or info is greatly appreciated
All bulb and warning lights and reset FSS counter
Check torque of power steering damper line fittings
Engine oil and filter change
All fluid level check
Test battery
Check tire pressure
That's about it.
Good information you posted; somewhere along the way there must be a coolant change, so maybe it's in the 60k service...
First of all they preformed what is called the "Factory Flex Service "B" which appears to be a super duper oil change that includes "LOF (lube, oil, filter??), rotate & balance, air filter, dust filter, w/w blades, fuel additive, and check car over" (a lot of stuff). The oil, filters, blades, etc., cost $187.19, but labor was $332.50!
Then they replaced all 16 spark plugs and related stuff, which cost $161.28, w/ labor again @ $332.50!
Then they replaced "in-line fuel filter (non ML)" and hose clamps @ $72.84 w/ labor at only(?) $76.00.
And then, for no charge, they sealed lower strip on all four doors, which was part of a Campaign, and provided me w/ a C-class car rental for one day.
Bottom Line:
o Labor = $741.00
o Parts = $421.31
o Misc. = $40.00?
o Taxes = $91.98
TOTAL = $1,294.29!!
Bottom Line:
o Labor = $741.00
o Parts = $421.31
o Misc. = $40.00?
o Taxes = $91.98
TOTAL = $1,294.29!!
I ended up taking it to a very trusted mechanic and the total cost to me was $525. So i saved almost 50% but still used all the mercedes parts but saved a ton on labor
