COMMAND Unlock Code
I heard that on some cars (CLS, W210, etc...) you can hold down 3, 5, 7 for a few seconds and it will bring up the hidden menu.
I tried it in my 2003 W220 with no luck.
http://www.freenetpages.co.uk/hp/tow...HIDDENMENU.PDF
Steve
Steve
http://www.mercupgrades.com/comand/C...rvice-Mode.htm
Steve
Because people see documents with pictures from Comands (w211, R171) that look similar to the S/CL-Class Comand APS DVD they believe that their Comands work the same.
Thats not the case !
Only the front bezel look similar the rest is different in many ways.
Fact is, there is no softkey (DVD or TV) unlock, even if there are people that want to believe so much in it.
With a special DAS System you could enable TV while you drive, but thats all.
(This applies to the R230 Comand APS as well)
Even if this is not what you wanted to hear, please spread this information so we may get rid of the farytale one day.
(maybe someone can add it into a FAQ?)
Cheers, Frank
I have a Japanese imported 2004, S 500, W 220.
I want to enter the engineering mode to activate MP3 and change DVD region.
If any one can help by telling me which buttons to press and which sequence, i will really be obliged.
Anyone knows how to remove parental block? I used Mute+1+3 to get into engineering mode, however, I do not know the code to access the secret menu. Please send me instructions to access secret menu on 2004 S500 US version.
