W220 Airmatic
Old 05-09-2006, 09:52 PM
02S430's Avatar
W220 M113K
W220 Airmatic
I have an 02 s430 and it has the airmatic warning light on, but when you turn the car on it goes up no problem and when you press the button for the car to rise it gives no problem and goes right up and stays. (tested to see if weight on the hood would bring it down and nothing it stayed strong, brought it to a specialist and he test the seals by spraying water to see if the front was leaking but nothing, he qouted $200 for something that needed to be done. wondering after reading these forums its the relay also any ideas?
02 S430 67k all lights upgraded to 03 plus thanks to ebay all OEM new, 20% tint all around
Old 05-10-2006, 10:14 AM
02S430's Avatar
W220 M113K
Is there any1?
Old 05-10-2006, 10:41 AM
kenstudios's Avatar
I would recomend changing the relay and see what happens. Do it fast coz those relays tend to take the entire airmatic system with them if not replaced.
Old 05-10-2006, 11:45 AM
Oxygen's Avatar
W220 S65 AMG
Kenstudios, since it seems that you are pretty educated on the topic of Airmatic, I am interested in changing out my relay before it ****s out my Airmatic on my MY2003 S500.
Can you give me some information:
What kind of relay is it?
Where do I buy it?
Where do I install it? (Picture would be nice)
Old 05-10-2006, 11:49 AM
Oxygen's Avatar
W220 S65 AMG
Here is the diagram...
Old 05-10-2006, 01:30 PM
kenstudios's Avatar
I dont have the diagram but it's in the fuse box on the passenger (right) side engine compartment. It is the 1st relay (O) is for the air suspension and the second (N) is for the secondary air pump. Look on your manual and locate these relays.
Also with the 03 models you shouldn't have these airmatic problems so Oxygen, you shouldn't have anything to worry about.
Old 05-10-2006, 07:31 PM
02S430's Avatar
W220 M113K
W220 Airmatic
funny because i knew what i was talking about the parts guy at the dealership didnt. i hope he wasnt looking at his computer too lol(over the phone)
Old 05-11-2006, 04:39 PM
02S430's Avatar
W220 M113K
W220 Airmatic
Nope its not the relay, idk what to do now seems like back to the drawing board here. taking it in to the dealer asap
Old 05-11-2006, 07:24 PM
02S430's Avatar
W220 M113K
like i said in the thread everything works fine, turn the car on and it goes up, hit the raise button starts and reachs the height fast and stays up, today i replaced the relay and nothing. Still says airmatic visit workshop, also looked at the top of the shock no leaking in the seals where the clear hose goes nothing loose and split detached. gonna bring it in asap thanks if you can tell me anything else
Old 05-13-2006, 12:41 PM
02S430's Avatar
W220 M113K
any1?
Old 05-13-2006, 06:20 PM
dougl65's Avatar
One of the other causes of Airmatic warnings is the height sensor attached to each wheel. If you take off the front wheels one at a time you will see a black box with a rod attached to it which articulates depending on what height the car is. This box is attached to the inner wing just towards the front of the car from the suspension strut. My car started giving airmatic warnings and wouldn't rise when you pressed the button. If the car was started everything would work normally including the rise button until the car was moved then the warning (malfunction) reappeared. Simply by wiggling the connection block to this sensor cured the malfunction. It first happened when it was raining, so have sprayed the connector with waterproof spray. Malfunction had never reoccured. It is worth checking these connections are patent, clean and dry. This may not be your problem but it is certainly worth investigation!
Old 06-14-2006, 01:36 AM
georgedaman's Avatar
GL350
Originally Posted by 02S430
any1?
Di you get your airmatic fixed?
My car seems to have the same problem.The dealer changed a strut,leveling sensors,checked wireing for pinching(it was a problem on the E class) and the message still comes back sometimes.Since the car is under warranty im pushing them to take care of it but it looks like they are running out of ideas too.
Old 06-14-2006, 02:19 AM
Oxygen's Avatar
W220 S65 AMG
I keep hearing about these situations where dealers "run out of ideas" and simply can not fix problems... does any one else think that it's rediculous?
Old 06-14-2006, 03:01 AM
GL350
I just asked a thread about the Lemon law.I am not sure about it but some member went back to the dealer 4 times with some bumping driver's seat and the dealer cant fix it so far,so he filed a lemon law complaint.
Doesnt necessary mean that it will go through but never hurts to try
My car is in as i write ...for the 3rd time.
Old 06-14-2006, 08:06 AM
kenstudios's Avatar
It's hard for them to admit when they are wrong. They don't just say "they ran out of ideas", they just simply repair the wrong thing and have you pay for that then you'll come back and open another ticket with a totally unrelated issue. Welcome the the wolrd of stealerships.
Old 06-14-2006, 09:12 PM
sprink49's Avatar
2004 S500
This might sound simple but try disconnecting the battery for about 30 minutes...re-connect and see what happens. Won't cost you a dime.
Old 06-15-2006, 12:50 AM
02S430's Avatar
W220 M113K
battery
wont this reset the radio to where i have to put a code in to get it to work again? im not the first owner so I have no clue wat the code would be.
___________________________
02 S430
20% TINT
UPGRADED LIGHTS
68K
Old 06-24-2006, 08:34 PM
GL350
airmatic fixed!!!..??? (hopefully)
The car had a malfunction reading on the right back side...Turns out that the problem was in the left front side (too low) and when i was doing a sharper lright turn, it just set off the back sensor (Thats what i was told and it makes sense )It usually took a few days for the "Visit workshop" sign to come back but everything looks good for now..
Old 02-09-2007, 05:49 PM
standman's Avatar
Part No. Please
I am having the same issue on my s430. Does anyone have the part number for the relay?
TIA
Old 02-09-2007, 06:01 PM
sprink49's Avatar
2004 S500
TIA
The MB part number is 0025421319 which crosses over to Bosch part No. 0986332040.
Old 02-09-2007, 11:11 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
COMAND does not have a radio code. You don't need one. However, you may need to reset a number of items - for how, see post #14 at http://www.benzworld.org/forums/show...30#post2216730
Old 02-25-2007, 10:16 AM
brenner's Avatar
2002 S320-CDI
You said that when you "turn the car on, it goes right up", does that mean that your car goes down (overnight)? Mine has never gone down. If your car does go down, sounds like a leak...or did I misunderstand?
I had my car on a rack, and when I took it down, it sat very low. I let it run for a while, but it didn't raise. I finally read the manual, pushed the "raise car button and it came back up.
Old 02-25-2007, 11:22 AM
SUNILP's Avatar
2015 E250D
If your car went down after a lift, it has a leak on the top of the strut. It should not go completely down and if you keep doing that, it will ruin the bellows inside the strut.
Old 02-25-2007, 03:55 PM
brenner's Avatar
2002 S320-CDI
Airmatic
OK thanks...I bought 2 repair kits, will take a look tomorrow.
Old 02-25-2007, 07:30 PM
SUNILP's Avatar
2015 E250D
I'll be doing a few repairs in Seattle and i will try to take some pictures of the process so everyone gets an idea of what's involved for the repair.
Quick Reply: W220 Airmatic
