AC Fan stopped blowing
1phd1jd could be right. i better get mine checked as well.
My advice do it yourself Stealer will charge you way to much
PM if you decide to have a go at it I'll talk you thru it pretty simple swap
With regard to your problem I would have to guess that the blower fan is on its way out.
Good Luck.
DB
Check over on roadfly.com. I don't know if it would apply but my BMW 540 had a "end of line device" that went bad that caused the same symptoms. Also you might ask MBTECH on the repair and diagnosis section of this board....gotta be something simple.
as i said before my problem is that it just does not blow hard enough,its like i need another 2 levels to go higher,its a real pain when getting into a hot car.
Any ideas.Oh this is on a 2000 S430.
thanks
I asked about adding the rear air so my present unit can just concentrate on the front and was quoted a $15K price. Not worth it.
Yes it has to be a design fault, sad tho, when you think about it.It seems to blow on max to about what woul be mid power fan setting on most other cars.
I have played around with all the setting options and it really does not make that much diff.Just seems like if I could kick the blower up a few notches it would be fine.
i don't think the dealer ever really fixed it; 'cause they can't reproduce it;
if it happens again this summer, i'll take it for the a/c blower fan and regulator fix/replacement...i'm sure they've gotten enough of this at the stealers....
j.rho
so calif
01 s500s 62K
I took it all back apart and this time I noticed corrosion in the plug that attaches to the regulator...so I cleaned it thoroughly with emery cloth as well as the connection to the motor it's self...put everything back together and it all works great.
Thought I would pass this along for anyone else that has this problem. These cars are very sensitive to electrical connection corrosion issues. That being said....if change an electrical part be sure to thoroughly clean the connections !!
