Shifter Sticks in Park
Old Jul 24, 2006 | 02:56 PM
Oxygen's Avatar
W220 S65 AMG
After the whole fiasco with the alarm system... my car did something weird to me today.
When I press on the brake, the lever is stuck in park, and it's locked it won't move.
I pressed the pedal again, and this time it came free. I was testing it out, and gradually throughout the day it's getting harder and harder to come out of park. Sometimes it takes 10 tries to get out of park...
Sometimes when I press the brake I hear the lever click loud, and sometimes it clicks a tiny bit...
Is there any DIY fixes for this or is this a mandatory trip to the dealer?
Old Jul 24, 2006 | 04:13 PM
kenstudios's Avatar
Sounds like your shift lock sensor is going bad. If this is the first time it's doing this, I would give it some time and see if problem persists. I wouldn't too much worry about the noise but if the lock does not disengage then I would take it in for check up. Also, sometimes this problem is caused by wasting drink into the shift area and when the dirt dries up it jams the system. In that case a good clean up will resolve this. To do this you will have to remove the selector lever than gently pull out the wood covereing the selector and just clean that area well. Remember, don't force it out. Remove it gently to avoid breaking the attaching pins.
Start from the green arrow.
Old Jul 25, 2006 | 07:39 AM
PA55AMG's Avatar
2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
I had this happen on my 04 SL500, and it was the brake light switch. It is a two position switch w/ the first position activating the brake lights and the second position deactivating the shift lock. The switch is up by the brake pedal and the dealer fixed it in about 15 mins. I don't think there was any computer work involved, so you could probably just buy the switch and do it yourself.
Old Jul 25, 2006 | 03:54 PM
Oxygen's Avatar
W220 S65 AMG
I was in the Hamptons this whole weekend, so to save my self, I had the car in Neutral and had the key in the off position (could not take it out)... no one was stealing the car.
Went to my friends house, and OF COURSE I put it in Park... that's right, it never came out of it.
Called Roadside... they told me that there is NO WAY to get that unlocked. Had to tow it... towed it MB Southampton... they called me, told me that I will wait 8 to 10 days before they even LOOK at the car...
Called my service advisior, they are towing it back to my home dealership... 45 miles away...
I told her that they Roadside guy who screwed up the electric screwed up the shifter too
Old Jul 25, 2006 | 05:16 PM
kenstudios's Avatar
Now that just sucks. 8-10 days for a little switch. Hope the offered you a loaner. Good luck.
Old Jul 25, 2006 | 05:20 PM
newton22's Avatar
BMW E39
Give it to him.
Old Feb 3, 2009 | 05:43 AM
monoglobal's Avatar
2005 S500
Sometimes the repair will be a new gear shifter - solution
I have the plastic part in stock and I can ship worldwide. Log on to www.monoglobal.com.au to view and order the part.
Internal plastic lever is there to prevent children from inadvertedly moving the gearstick lever out of Park. Removing the lever may cause your car to roll away down a hill with your kids inside.
Choose from original plastic or high strength aluminum. Repairs can be done by any reputable MBZ shop in about an hour or two. No need for recoding with Star Diagnosis.
Old Feb 3, 2009 | 08:45 AM
Oxygen's Avatar
W220 S65 AMG
Yeah... I posted that 07-24-2006, 02:56 PM...
Old Feb 3, 2009 | 08:54 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Great idea!! but the pricing?? YOU MUST BE MAD!!!!!
Old Feb 3, 2009 | 10:23 AM
Quadcammer's Avatar
96 and 08 911 turbos
I believe that may be in australian dollars, but Im not sure of that, or what the exchange rate is.
Old Feb 3, 2009 | 10:44 AM
benz_addict's Avatar
V12TT
300 bucks for a little piece of plastic that I can fabricate my self (which I have), ahahahhahahahahaha
Old Feb 3, 2009 | 11:26 AM
my06clk's Avatar
Today it's 1.57 which is still waaay too much.
299AU = $190.23US.
MEtal is great idea though.. too bad the price is wrong
Old Feb 3, 2009 | 02:40 PM
S5LorinserF1's Avatar
2003 Mercedes S500 Lorinser
same thing happend to me cost $900 to fix at the dealership.
When this happened to me i kept playing with the shift knob moving it side to side up and down until it shifted down as it got worse it took more time to get it out of park
Also you could of removed the shiftknob and hit the metal shifter with a mallet and that would of took it out of park. Had two of my friends in there sclasses do the same thing.
