2001 S430 Headlights
Old Dec 11, 2006 | 10:27 AM
abcheng's Avatar
My mom has a 2001 S430 with halogen bulbs and I want to upgrade her car to HIDs as a christmas present. From what I've read on the forum, some module has to be modified so that the computer detects xenon bulbs ? Is there a certain reasoning for this? What problems would I encounter if I only installed the HID kit without having it reprogrammed to detect HID lights? Another question I have is since the cars headlight housing are designed for halogen bulbs, should I just purchase some PIAA or Sylvania halogen bulbs?
Old Dec 12, 2006 | 06:40 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Unhappy
Depends how much your mother is worth to you. The conversion to Bi-Xenon will cost $ 2,500 plus. The conversion to regular Xenon is not as costly, but technically not very simple to do, beause you need the automatic levelling of the lights. In both case you need the complete assembly, since your lenses are made for Halogen, for Xenon or Bi-Xenon they are different (2 options). Either way you won't be done by X-mas with neither options.
Just fitting so called "Halogen bulbs" with Xenon looks, is not quite close to Xenons.
Old Dec 12, 2006 | 07:56 AM
Mark_K's Avatar
2002 S430
Good advise bamberger_1!
Search this site there is a lot of info on this. For example:
https://mbworld.org/forums/showthrea...41#post1880841
I will be doing this ear;y next year.
Good luck
Mark
Old Dec 12, 2006 | 10:20 AM
abcheng's Avatar
If I was to purchase xenon headlight assemblies, how much work is required for automatic leveling? It seems like xenons aren't really worth upgrading to, since it seems stupidly complicated and expensive ($~1700?) for this car. I realize the halogen bulbs won't look as nice as xenon bulbs, but the main reason why I was considering HIDs is so it's easier for my mom to see at night.
If I were to convert the headlights from halogen to xenon, my main concern is that her car is still under warranty and even though a headlight assembly and some HID bulbs / ballasts won't cause any problems in the car, the dealerships here might use that as a reason to deny warranty claims.
Old Dec 12, 2006 | 10:37 AM
Check this out: https://mbworld.org/forums/s-class-w220/173177-up-smoke.html
Looks like an improper conversion from Halogen to Xenon/BiXenon.
If you have warranty on the car, dont DIY. If you want to improve night vision for your mother, have the dealership to convert it to Bi-Xenon, but$$$$$$$$$$.
Any other option is no improvement.
