Battery Tender harness location
Old Apr 12, 2007 | 06:26 PM
LetsJet's Avatar
355 F1 Spider & ......V12 w220.176
Are there a set of terminals in the engine bay to attach a Battery Tender harness? I know the battery is located in the trunk but I don't want to leave the trunk open while it's connected.
Old Apr 12, 2007 | 06:37 PM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
there actually is a way from the trunk to keep the trunk light off i believe im just not sure how
Old Apr 14, 2007 | 11:51 AM
srknutson's Avatar
2004 S500 & 2011 Mini JCW
I have attached my battery tender by using the included hardwire kit. I then connect the tender unit and place the unit outside behind the car. I then close the trunk place a cotton towel on the rear bumper to protect the paint from the cord and plug in. I've used this application two winters now with great sucess.
Old Apr 14, 2007 | 12:10 PM
raymond g-'s Avatar
99 E320
dont know about terminal connect under the hood for your model. generally, if
the battery is in trunk, then trunk access only. if it's under the seat, then there
is usually a "+" terminal near hinge on driver side.
to extinguish trunk light with lid open, try pulling the plunger/switch outwards
Old Apr 14, 2007 | 04:50 PM
okc329's Avatar
1997 E320 (silver/black)
I would think...
that you would use the terminal under the hood. On my car, you connect jumper cables across that terminal (+) and the lift ring on the block as a ground.
Old Apr 14, 2007 | 07:06 PM
LetsJet's Avatar
Do you happen to have a picture of where that is?
Old Dec 17, 2007 | 09:59 PM
LetsJet's Avatar
Bump....
I couldn't find a pos. terminal in the engine bay.
BTW - I have an '04 S600
Old Dec 17, 2007 | 11:39 PM
rccmerc's Avatar
Originally Posted by LetsJet
Bump....
Drive it more and enjoy and stop this charging madness
Old Dec 17, 2007 | 11:48 PM
LetsJet's Avatar
You're funny............... looking
Seriously, I have tenders because I have a few different cars. I need a good solution. the best would be to attach to terminals in the engine bay.
