Upgrading to 03-06 Xenons Aftermarket!!
White S63 AMG W/Designo Interior
do you guys listen???call
Call ----->
Advantage Auto Body Parts of Texas
217 Bradford St
Grand Prairie, TX 75051
(972) 266-2431
and ask them if they have the bixenon headlight for and 03 04 05 06 s500? and they will most likely have a used set for like 950..........thats where i got mine paid by phone with my credit card.............please listen![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Call ----->
217 Bradford St
(972) 266-2431
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
Thats right good point, but what about this one
http://cgi.ebay.com/ebaymotors/00-06...mZ180287035532
IF you have Factory Xenon Headlights:
* For the Originally Xenon equipped car owners, we can custom pre-wired one to fit your car too, however you will not be able to use your factory Xenon HID on these new headlights. Since you do not need your factory Xenon HID anymore; you can sell it at a decent price and get a whole new set of Headlights with Xenon HID pre-installed from us. The one we custom pre-wired for you will also be plug & play and the installation is also straight forward. You will need to contact us and let us know if you fall into this category so we can do the necessary change for you.
if you're going to try those ebay lights, please let us know how it all works out...good luck
02 S500 Sport
Call ----->
217 Bradford St
(972) 266-2431
Call ----->
217 Bradford St
(972) 266-2431
JDP thx for the input
i would get the bixenon but thing is i want to retro another projector to replace the factory one. just would like to get more light output and color out of the headlights, no sense in forking over $700-900 in OEM headlights that I want to hack into and potentially loose the autoleveling which would be the main reason I would want to go with OEM.
Thats Why I am going to go with aftermarket. Nothing tops OEM quality I agree with that but that is why I am going to pretty much go with aftermarket housing and then retrofit the best of OEM HID parts which when it comes to headlights our cars are not equipped.
If you keep looking on Ebay you will come across a cheap set, thing is do not look up S500 headlights i used to search for "S55 headlight" and would come across a few sets a month at least, there was a OEM set on there just last week for approx $650 buy it now and I thnk $30 shipping. im sure its sold now but they are pretty common on ebay
so like i said anyone know if I disable Autoleveling if I will get a message on the console?
s430 2002 and s500 1996 mercedes benz
HEAD LAMPS
I have a 2002 s 500 and I recently found a guy after 5 months of search and agony who did the upgrade for me for just $80. I purchased my aftermarket xenon projector headlights of eaby for $400. The car looks totally awesome and looks like an 06.. Anyone needs help let me know... thanks
#32
I definitely need some help or input on this. I have a 2000 S500 with stock Xenon HIDs and I wanted to do the aftermarket upgrade myself. Went out and purchased some really nice black housing HID headlights that are for 2003+ models Sclass and instead of one plug that my 2000 model has the 03+ models have 2 plugs. So how do I intergrate the wiring from old to new? This sucks. Been sitting on these new headlights for literally 2 months now! Please help somebody
#33
The main plug is plug and play.. that is almost all you need.. the other plug near the middle of the car needs one pin grounded.. Take the cover off above it and see which end has the brown wire. It will be one of the end pins and ground that wire.. Do the same for the other side keeping in mind the grounding pin isn't mirrored so you need to check that one too.. after that you are all set.. it's really that easy.
#34
Thanks cmpcpro. I will get up and try that in the morning and let everyone know how that went. And to give everyone a heads up on the new headlight set that I'm running, it the ones from CARDID.com. Great set if you already have a 03+ w220 s class. Buy since I have a 2000 model, it's been damn near impossible for me, thus far. These are NOT cheap headlights at all. And you use the original DR2/DS2 bulbs and stock igniters from your original headlights. Plus the new aftermarket lights come with the LED daytime strip seen on Audi and newer model Mercedes. Awesome set up! I haven't seen it done yet nor have I seen them on any w220, EVER. I'm very excited to take cmpcpros' advice and get this darn wiring right. Wish me luck. And I'll definitely post pix very soon
#35
if you are going aftermarket, these are what you need. quality, plug and play with OEM xenon equipped. a lot of those ebay lights are made for the halogen (430) cars and some include just a HID conversion kit already attached claiming it as xenon hid (will not work with s500+)![](http://www.oxilab.info/huang4.jpg)
![](http://www.oxilab.info/huang3.jpg)
![](http://www.oxilab.info/3.jpg)
#36
#37
Ok. Help me out with this one more time. My 2000 has only 1 plug coming from my ignition harness. There are two open plugs coming out of the aftermarket lights. How do I integrate this? Second, will all of the lights work properly- hi/lo beams, signal, and parking lights? HELP. :-)
#38
#39
Hi well you can buy after market projector headlights from ebay and have them installed. If your car is non-xenon the upgrade is real real easy. you can do it yourself. But if your car has factory xenon then you need to buy after market xenon projector headlights that come with ballasts and ignitor. They are a little hard to install unless you can find someone who can do it for you. My guy did my upgrade in 20 mins. I was so surprised that i could not believe it. Earlier i had taken my car to atleast 6 workshops here in GA, but no one could figure out the installation. Well if you are on the east coast my guy can help you upgrade to the newer headlights. Just let me know. I a in atlanta, Ga.
good luck!!!!
good luck!!!!
#43
Go to eBay, then advanced search, then by seller, and search for fishcake321, then search within his 470+ items for the headlights. High-quality units...
No affiliation, other than as a satisfied customer.
#47
OK - I didn't pay enough attention to your question. The lights that I bought were not bi-xenon!
Unfortunately, the installation was not quite that simple for me. I bought and installed the light assemblies, and only at that point did I discover that they were for the auto-level system. My S430 had halogen lights, and did not have the auto-level system.
The low-beam HID lights pointed to the ground, and the car has no system to move them. I hooked the lights momentarily to a friend's car that did have the auto-level system. The HID lights moved to an aimed position, and stayed there. I plan to install a European manual HID adjusting switch so I can adjust the HID lights from the driver's seat.
Hopefully, you should have no such problem - just plug the existing auto-level plugs into the new lights, and you should be in business. At least, you will be if the plugs on the 2000 S430 are the same as on my friend's 2002 S430 - I have no way to know that.
I am making no assurances that this will work. You need to discuss this with the vendor that you choose.
The headlight assemblies that I bought were halogen high beams and fog lights - not the bixenons, and came complete with the auto-level motors and all bulbs, even the parking and turn signal bulbs. Choose the output color of the HID bulbs that you want - I would recommed the warmest that you can get, so there is as little difference in the halogen high beams and the HID low beams.
If you want to keep your bi-xenons, these lights may not be what you want! I have no idea whether it would be possible to swap your lights into the new housings, but it doesn't seem likely. You need to see if these folks have the bi-xenon headlight assemblies on their site.
I have no idea how well it would work for you to
#49
After hours of reading multiple threads with scattered info on this swap. here is the thread with everything you need to convert you 00-02 factory xenon into the 03 bixenon
Scroll down on the first page for some great photos.
https://mbworld.org/forums/showthrea...418&styleid=20
I'm only posting this link after I spent hours searching through all these different threads to try to help the next person in the future and save them the hours of searching
Btw the new ones look awesome!! Makes the whole car look 5 years newer
Thank you to the original posters helping another member navigate this upgrade
