Question about squeaking noise from '03 S500
Old May 31, 2007 | 04:02 PM
EastSideS500's Avatar
2003 S500 4Matic
I started hearing a chirping sound from the suspension when I go over minor bumps or imperfections on the road...
Any idea what it could be?
Im bringing it to the dealer next week...
Please advise...
Old May 31, 2007 | 04:37 PM
kenstudios's Avatar
Ball Joints. Search the forum for "suspension noise" or "ball joints" and you'll find your problem. Very common.
Old Jun 1, 2007 | 07:16 PM
2003 S500 4Matic
I see...
The noise isnt there anymore.
I'm taking it in tomorrow for an oil change and all of that...
So I will mention it to them...
Thanks for your help!
M
Old Jun 2, 2007 | 05:41 PM
ebolick's Avatar
2000 S430, 1999 E 320, 2 K5 blazers,
i have had that noise after i had the everything in my suspention replaced. they adjusted my chamber and the noise was gone.
Old Jun 12, 2007 | 06:35 AM
2003 S500 4Matic
Yep... Left lower ball joint and Right upper Control arm had to replaced.. Its now completely fixed... $1700 (cost), but they covered 50% of parts through the Warranty even though its at 51,500 miles! So, the final total was $1100.xx
Old Oct 31, 2007 | 02:25 PM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
wow - i thot the parts were only like $75 and $200, respectively. how much labor?
Old Oct 31, 2007 | 03:55 PM
bzliteyear's Avatar
my bad for not getting the car inspected prior to purchase, but i can't believe this S55 which has been MB dealer only serviced did not previously find these problems in the past 6 yrs(starmark expired aug 06). by way of background, car had 82k miles at expiration, and currently has 91k miles. Do you think the prior MB dealer should have caught these?
My friend just took a look and gave me these observations:
1) Front control arm struts are shot: 2 pieces + 1.5hr labor
2) Lower ball joints has play on both sides: 2 pieces x 2, + 4hrs labor
3) Lower control arm joint where the strut sites has significant amount of play..Special order item, but only about 0.75 hrs of extra labor if you do the lower ball joints.
4) Tie rode ends has play- x2 and about 0.5hr of labor
5) Front wheel bearings needs to be adjusted. I can repack the front bearings and adjustment.
6) Upper control arm ball joints have very minimal movement...it can be left alone for a bit.
Old Nov 1, 2007 | 01:04 PM
2003 S500 4Matic
I will find the invoice and post it as a picture, so u can see the breakdown of charges.
Old Nov 1, 2007 | 09:56 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
Im Sorry But I Had My Ball Joint Replaced For $250 Parts And Labor.......
