Water Leaks...
Old 10-15-2002, 09:48 PM
boltonblue's Avatar
15 AMG S63 4-matic coupe
Originally posted by DSMIT
you got my attention ,,,,thought you were serious
you may need more pressure that a can of compressed air
you may need to stop by a service station or your local dealer to have them provide more pressure
be real carful blowing out the drain lines.
If you build up to much presssure you can pop the line off of the internal fitting. Then you have to remove the roof liner to get to it.
My ML had a leak problem on the sun roof. It only occurred after a very heavy rain. The drain was cracked around the seal where the tube exits. Under very heavy rain the water couldn't drain quickly enough and would back up, then seep down the side of the drain tube into the interior.
Old 10-17-2002, 01:24 PM
benznut's Avatar
Do you own these cars simultaneously?
Old 10-18-2002, 11:20 AM
Kar don's Avatar
Mercedes-Benz
if they can't fix the leak, lemon the car.
Old 10-18-2002, 11:26 AM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
they cant grow lemons in germany
Old 10-25-2002, 04:44 PM
rsatmans's Avatar
None
leaks
my 2001 e320 has leaks form the moonroof to
Old 10-28-2002, 04:45 PM
mrgolf25's Avatar
rx300/cadillac sts/e320 2k3
you know whats funny. you pay $250 000 canadian for a car you shouldn't have to worry about leaks. i've had a cadillac sts for 10 years now and i haven't had ANY leaks whatsoever
Old 10-31-2002, 11:35 PM
  #32
borges2001's Avatar
lexus lx 470
Just got a 02 s430 10 days ago and it's leaking water from the passenger roof light.When i took it to the dealer ,the manager insisted i left the roof open .
It's happened three times and i don't know what to do HELP !!!
Borges
Quick Reply: Water Leaks...
