bad sun visor, driver side
Rating: Thread Rating: 2 votes, 5.00 average.
Old Oct 29, 2007 | 03:51 PM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
you guys ever have problems w/ the sun visor being very difficult to move?
i thot it could just be lubrication, but mechanic saying likely the springs inside are gone and need to replace entire piece? how much is that?
thx.
Patrick
Old Oct 29, 2007 | 07:01 PM
icwater's Avatar
2000 S430
seem to remember some people posting that it was around 285 freakin bucks
Old Oct 29, 2007 | 07:33 PM
comforta's Avatar
2003 S500 4MATIC
Dealer told me it was 200 - 250 for the part
Old Oct 29, 2007 | 10:48 PM
bzliteyear's Avatar
$210 retail and $144 wholesale according to my indep mechanic.
funny thing, i think it's part of the S55 Technical Svc Bulletin, but I can't find the 2002 S55 to see if possibly it could be covered. anyone have access to that?
Patrick
Old Nov 22, 2007 | 07:49 PM
lernik21's Avatar
s500
yeah my driver side visor pissed me off so much, once i hit it and cracked the 5x mirror and since then i havent opened it once.
Old Nov 23, 2007 | 03:13 AM
jdpfresh's Avatar
s500
yeah i had an issue with the driver side visor as well. i tried my hardest to fix it myself, but i just couldnt find the problem. took it to the dealer and they had to replace the whole unit, cost me around $250 for the part and install
Old Nov 23, 2007 | 09:16 PM
Trooper2's Avatar
S-430
Sticky driver visor…
I also had this problem with my S-430 ’00. I think it’s fairly common; however I was successful in eliminating that problem. I saw this suggestion on another MB forum. First remove the entire visor (two screws), take your time. Don’t loose it when I say this get some WD-40 & insert the (red) straw into the spray nozzle. Slowly and carefully insert the straw into the shaft part of the visor and spray intermittently. DO NOT SATURATE THE VISOR. Do this in sections around the shaft; I did it four times as if I was trying to lubricate all four sides of a box. Please be careful not to get any WD-40 on the material portion of the visor. Once this has been done work the visor around and around several times. When done reassemble the visor. Finally get a small towel and spray a small amount of WD-40 on it. Fully extend both visors and wipe the dry filthy grimy substance away. It may sound a little weird but it worked for me.
Old Nov 27, 2007 | 07:28 PM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
how about a sagging visor? It hangs down a few inches when you have it pushed all the way up.
Is there a fix for this?
Old Aug 26, 2008 | 05:18 PM
Chemist69's Avatar
2003 S 500 Sport
Passenger visor
My passenger visor (2003 S500 Sport) sags. Anyone know how to fix this?
Old Aug 26, 2008 | 08:26 PM
02S430's Avatar
W220 M113K
mine does too think you just need to replace the whole unit
Old Aug 29, 2008 | 04:26 PM
occarfan's Avatar
2002 Carrera, 2003 S430, 2007 GL450, 2004 E55 AMG
Sagging visor happened to me too. Luckily during warranty period.
They replaced the whole visor unit.
Old Jan 11, 2013 | 03:00 PM
legatolimo's Avatar
'05 S430 4MATIC Sport, 2009 GT Zaskar MTB
I have a sagging drivers visor as well. I guess I'm going to have to replace it.
Old Jan 12, 2013 | 07:57 PM
AH1W-COBRA's Avatar
2003 S500, 03 C240, 03 E320, 03 tahoe
me too, sagging/stiff
all can be attributed to the "stiff" pivot rod. the dealer told me $450 so you guys are getting a deal. if they are only a couple hundred ill replace it now.
Old Jan 10, 2016 | 06:20 PM
Woolfland's Avatar
2003 S 500
The WD-40 fix described above worked for me on my drivers side sun visor. Thanks a bunch! : )
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
