Aftermarket Warranty or not?
They call it "Bumper to Bumper" or "Premium Plan" with a $100.00 ded. The company is in Florida (I'm in CA) Standard Guaranty Insurance Company.
I have read the small print and fully understand the nature of some aftermarket warranties to avoid paying for repairs. The credit union swears they don't have this problem with this company.
Should I self insure myself for that price?
Also for that price, be sure electronics are covered. Radio, CD/DVD readers, navigation system, handsfree phone system, and the like.
Lots of "bumper to bumper" warranty plans leave such components out.
BTW, the most important components to be covered would be pump, valves and seals.
Radio and CD player are not covered but the GPS is.
Thanks for your help in advance.
But that aside.... Be very careful as whoover stated about those warranty companies.. Very few actually will be of any assistance to you if you have some catastrophic suspension issues...
My opinion is slightly one-sided because I am just not into those warranties but if you must, try to find someone who will be very specific about the coverage that pertain to your vehicle keeping in mind that your vehicle is unlike many of the "other" vehicles they cover so that basic catch-all language might leave you in a jam as it may not apply to your car at all.
I understand that company in Ontario was fairly popular with benz cars.. MErcury. Did you try them? I may be mistaken but they just popped in my head.
chryslerservicecontracts.com- michael 866-278-8823
Tell him LetsJet told you and let me know how he does for you.
Good luck
Actually just read this is an '03.... Depending on miles he might not be able to help. Give him a call.
1875 for 3 yrs, Dealer told me it should cover everythnig, But we'll see.
Platnium Coverage
►Gas Engine: All internal lubricated parts: oil pump, pick up screen, pistons, rings, connecting rods, main and rod bearings, wrist pins, crankshaft, internal timing chain or gears, timing belts, push rods, rocker arms and shafts, intake and exhaust valves, valve springs and retainers, camshaft and bearings, hydraulic and solid lifters, distributor shaft, intake and exhaust manifolds, harmonic balancer and bolt. Engine block and cylinder heads are covered only if damaged as a result of a failure of an internal lubricated covered part. Cylinder head and manifold gaskets are covered for coolant leaks only. Seals and gaskets, with the exception of cylinder head gaskets and intake manifold gaskets, are covered only in conjunction with a covered repair. Coverage limited to above named components.
►Diesel Engine: (only with Applicable Surcharge) All of the gas engine components named above, as well as, the fuel distributor, fuel injection pump, fuel regulator and injectors. Seals and gaskets are covered only in conjunction with a covered component. Coverage limited to above named components.
►Transmission: All internal lubricated parts of a manual or automatic transmission, including torque and lock up converters, flexplate and flywheel. The transmission case, gaskets and seals are covered only as a result of the failure of a covered component. (Exclusions are clutch, pressure plate, throw out bearing, linkage, cables, shifter, electronic switches, solenoids and clutch hydraulic cylinders). Coverage limited to above named components.
►Drive axle: All internal lubricated parts, including ring and pinion gears, spider gears, side gears, bearings, bushings, spacers, yokes, drive shafts, universal joints and CV joints. CV joints are not covered if the CV joint boots are torn or damaged. (Exclusions are CV joint boots, locking hubs and wheel hubs). Drive axle housings, front or rear, are covered only due to the failure of a covered component. Seals and gaskets are covered only in conjunction with a covered repair. Coverage limited to above named components.
►Four Wheel Drive and All Wheel Drive: (only with Applicable Surcharge) All internal lubricated parts, drive gears, sprockets, chains, forks and bearings. Transfer case/housing is covered only if damaged by an internal lubricated part. Seals and gaskets are covered only in conjunction with a covered repair. Coverage limited to above named components.
►Turbo/Supercharger: (only with Applicable Surcharge) All internal lubricated parts, vanes, shafts, bearings, and housing (if damaged by the failure of a covered part). Seals and gaskets are covered only in conjunction with a covered repair. Turbo/Supercharger must be factory installed for this coverage to apply. Coverage limited to above named components.
►Air Conditioning: (Factory installed only) Accumulator, evaporator, clutch, compressor, condenser and dryer. Refrigerant, evacuate and re-charge are not included. (Exclusions are component failure due to contamination of refrigerant oil, A/C conversion from Freon to other chemicals and any retrofit process). Coverage limited to above named components.
►Steering: Manual and power steering gearbox, rack and pinion unit (short rack) and power steering pump, center drag link and pitman arm. (Exclusion: alignment). Coverage limited to above named components.
►Electrical: Alternator, solenoid, starter motor, generator, voltage regulator, front and rear wiper motors, front and rear washer pump, power window motors, ignition module, keyless entry transmitter and receiver, power seat motors, power door lock actuators, power mirror motors, rear window defroster switch, power sunroof motor, power antenna motor and fuel pump. (Exclusions: failures due to any external force breaking the component, i.e. accident, vandalism, misuse). Coverage limited to above named components.
►Cooling System: Electric fan motor, fan clutch, water pump, thermostat and gasket, radiator and heater core. Coverage limited to above named components.
►Brakes: Calipers, master cylinder, wheel cylinders, and power brake booster. Also, the following ABS components are covered: electronic control processor, pressure modulator valve, wheel speed sensors, hydraulic pump/motor assembly, isolation dump valve and accumulator. (Exclusions: linings, rotors, pads, drums, hardware and any component failure due to brake fluid contamination). Coverage limited to above named components.
►Suspension: Upper and lower ball joints, upper and lower control arm shafts and/or bushings, stabilizer bars, torsion bars and spindles. Coverage limited to above named components.
►Seals and Gaskets: Seals and gaskets are covered only if required in conjunction with a covered repair. Cylinder head gaskets and intake manifold gaskets are covered for coolant leaks only. Coverage limited to above named components.
TOP
I have come across several companies that will not even write an aftermarket warranty for an S55 that does not have any of the original Mercedes warranty left. "Warranty Direct" will not write on an S55 period. After your posts I've come to the realization that most (or all) "aftermarket" companies are going to have loopholes in their parts recognition of an S55. I feel like my money will be on a craps table (on the Don't)! This is why I was thinking of self insuring myself.
my06clk: your post gave me the idea to ask my local Mercedes dealer who they use as a aftermarket warranty company, and who would (if any) cover an S55's specific suspension parts (I'm waiting for their response). I will also research Mercury.
Letsjet: I will call your guy tomorrow thank you for the referral!
1. Very unlucky people who buy car that had problems already.. ( research the history of your car thoroughly and have it checked before purchase)
2. Folks who take dealerships word as a commandment and do whatever they say without checking here and other places for better advise and prices..
You don;t have to be a DIY'er, but If you apply these principles, you will find your cost of ownership reduced greatly. and you will better enjoy driving and repairing your car.
ALso remember. Even though your car is out of warranty, Mercedes is still committed to providing you 24hr roadside assistance and this is one of the reasons I still buy their cars...This means gas, batteries, towing, and in some cases like I experienced, phone conversation with an on-call technician who actually troubleshot with me on the phone before we decided if he needed to send out a tow truck or not.
Fortunately I managed to get the car started and drove it to the dealer the next morning. They verified the problem, i paid them 90 bucks, bought the parts over the counter, came home and installed them and save myself 60% of their quote.
IF you have a dealer troubleshoot a problem for you, you still have the option of getting it repaired somewhere else and they will only charge you for the hour or so it took to find the problem.
good luck
good luck
S55 warranty is impossible to get it
Do the piggy bank method.
