tire fitament ????
2000 S430
tire fitament ????
since my car came with the lowenhart ld5's I belive the size is 20x9.5 with 245/35/20 I was wondering if i could swap out the rears too a 275 or 285 size is this possible? or a bad idea?
2000 S430
so I could swap out the rears to a 275/30 and it wont rub when its droped? will the speedo be of since the height aspect ratio is lower than the front 35?
2007 S550
2007 S550
1 Post
AMG E55, Stage 1, Strait Pipe from Primary Cats
Only a custom offset wheel specific to you car would a 285 work. I saw a guy with Zone wheels with 285's, I think he had a 44 or 46 offset...... 99% of the time a 275 is as wide as your gonna go, especially if your dropped. I run a Nitto(used by renntech) 275/30/19 and I am really low with rear well fender modifcation. The Nitto is the widest tract 275 around.. Im ran a 20x10 in the past with a toyo T1R 275/30/20 with it slammed and it worked nicely.. I would highly recommend the toyo T1R on a 20x10 rear due to it's rounded tract that tucks nicely..You will be rubbing with a 20x10 rear that is lowered so to get it right you need to mod the well and run the right tire...good luck
2000 S430
opps i miss that part on the link thanks!
well i guess it will be 275's then on 9.5 or 10" since these tire are new I m gonna try to find two rear LD5 I understand it might be a little hard but I guess I can try. So my mod list seems good now, rims,tint,drop, and S55 exhaust.
