Adding SAT radio and ipod to a 2000 S430/500
Old May 9, 2008 | 05:10 PM
Rolex5513's Avatar
2000 S430, 2008 E350
Hey guys I have a 2000 S430 and I really want to add SAT radio and perhaps an ipod to it. The SAT is for sure. I am wondering what you have all done. It would be nice to have it hooked up direct over the wireless option which is really bad. I am in Orange County (NB) California.
My care here...
thanx
pat roberts
rolex5513@mac.com
Attached Thumbnails Adding SAT radio and ipod to a 2000 S430/500-dscf1963.jpg
Old May 10, 2008 | 02:03 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
My care here...
thanx
pat roberts
rolex5513@mac.com
In that year Factory SAT Or IPOD is not possible. YOu have top go aftermarket for that.
Dension has an integrated IPOD kit, called the gateway 500, and SAT yo can get anywhere but it will have to be a plug-in.
Old May 10, 2008 | 03:07 AM
westcoast5's Avatar
2000 S430
do you have more info on that on where I can get it?
Old May 11, 2008 | 07:39 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
https://mbworld.org/forums/audio-electronics/194660-gateway-500-most-o-good-unit-poor-documentation.html and https://mbworld.org/forums/showthrea...51#post2471051
The Dension unit has IPod, AUX, and USB input. You may be able to hook your Sat radio into it.
Old May 11, 2008 | 06:09 PM
Rolex5513's Avatar
darn
I just want the best possible sound quality. At least if the cables could plug directly into the back of the factory radio the sound would be good. I dont mind controlling the SAT from the aftermarket unit, the FM modulator idea is just so aweful.
gonna have to think on this
Old May 12, 2008 | 06:42 AM
Skylaw's Avatar
Follow the links in post #4. You will see that the Gateway 500 input to your HU is fiber optic. The device converts iPod, AUX, and USB to light.
One contributor has run audio tests comparing the MB iPod kit (which uses an AUX input and in many cases requires a supplemental amplifier) to the Gateway 500, and found the Gateway to be superior. https://mbworld.org/forums/audio-electronics/234260-oem-ipod-adapter-vs-dash-cd-vs-gateway-500-a.html
The Gateway 500 is not FM or even FM modulation fed through the antenna leads. It is probably the best option for what you want to do in your '00 W220, as my06CLK suggested.
Your model does not have any AUX input for its COMAND at all. Some other model years do. That's why the MB iPod kit cannot be used - the kit requires an AUX input. Your COMAND was also built without the connections for satellite radio, which is why you can't use the MB Sirius kit.
Old May 12, 2008 | 04:13 PM
Rolex5513's Avatar
Thanx
I will give it a look
