s500 05 navigation problemHey guys,
s500
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
I believe the flash is already on the DVD.
YOU have to hit the Service button, then software, it will ask you to insert disk and insert the DVD into your system and let it load the flash first.. then try it.
I just checked mine, it is version 2006.1
I can't see changing at this point, there can;t be much difference between 2006.1 and 2006.2 map wise.... There are too many changes around where I live.. My Ex just bought a 2008 Pathfinder and her map still doesn't have detail of my old neighborhood and its 5 years old.
2006.1 is much better than my original DVD so I'll leave this one. I can get a copy of the newer version to make a test but only if there is a real benefit from flashing..
Can anyone shed any light on what you actually get from flashing except the ability to read the next disk?
I think I had that done already I'm not sure.
did you have a version older than 2006.1 to begin with?
s500
Sasha,
I just went to check it and when I hit service it doens't give me option software....
Sasha,
2006.1 and 2006.2 map DVDs are very similar. It's just that 2006.2 works with the updated firmware only while 2006.1 works with the old firmware only.
The 2007 map DVD had a problem with car pool lanes and should not be used. The 2008 map DVD has many more points of interest and I find it very worthwhile. If you don't get the flash, you are stuck at 2006.1 for ever. It's your choice of course, but it seems every restaurant in my area is now on the 2008 DVD.
s500
This is incorrect information. The NAV processor firmware has to be updated in order to read any map DVD from 2006.2 on. The update is not on a map DVD. It's on a separate service DVD that only the dealer has. The dealer replaces the map DVD with the service DVD and does the update. Then they replace the map DVD.
THank u for all your information, I will still try to bug my dealer to do it... do u know how much the 2008 DVD cost?
BTW.
Is there anyway to tell if my unit has the proper softwar update? Do you have the number of the flash?
Inside my hidden menus., My NAVI software version is 1/Q2.39
the H.U software is DC-01-05-015.006.0028
is this the current flash?
Thanks..
#33
Cool My bad.. I thought it was on the DVD.. I will see if I can get a hold of a 2008 DVD. later in today..I will flash my car if necessary.. POI's is my only gripe about the disk that I am using now.. I also noticed it doesn't give a business listing.. does the 2008 dvd have that? It's no biggie if it doesn't s long as the POI's are better I'ts worht its weight in gold to me.
BTW.
Thanks..
BTW.
Thanks..
#34
tomorrow..I'm anxious to see the POI changes.. Too bad the voice can't be changed.. My girlfriend refers to her as 'My chick".. LOL
BTW. mute +1 +3 + 7 + left arrow works all the time unless the firmware
deleted it.
#35
'06 S uses a different unit. The good news is that it will read DVDs (soundtrack only for movies, but lots of .mp3 files). Bad news is they deleted the engineering menu.
#36
All this time I thought 04, 05 , and 06 were the same.. I read DVD's also. why would they have a different unit for 06 when they all changed on 07??
Engineering menu tel you nothing anyway.. just a bunch of info. The only thing I can change is the intersection zoom feature for the nav which makes no sense to me at all....otherwise just a bunch of Software and config. information.
#38
Wait..
All this time I thought 04, 05 , and 06 were the same.. I read DVD's also. why would they have a different unit for 06 when they all changed on 07??![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
My nav SW level is 1 / Q2.53
#39
2005 S500 4-Matic, 1978 450SL
#40
Bluetooth
To give you a summary, which will help you sort through Skylaw's excellent link:
If your car never had a phone installed before, you need to do two things:
1) Have the dealer install the phone kit. This is sometimes called "prewiring" or "MHI" (multi-handset inteface). It actually adds some electronics, voice-control and wiring, as well as a phone cradle. It usually costs about $1,500.
2) After you have the cradle, you buy a "bluetooth puck" from the dealer or online at http://www.wireless4mb.com/ . It's about $400.
If you're lucky and your car already has been prewired, you will have a cradle in your center console. But chances are you don't.
For this expense you get a very nice installation, well integrated with the COMAND and dash display. It pauses your audio when you're on the phone and the voice control is great. It even recognizes cities pretty well when setting a nav destination. But almost $2,000 is a lot for a phone integration. There are also third-party solutions, but none are as nicely integrated.
#41
s500
#42
s500
#43
If you lift the small flap in your center console you will either see a solid black felt floor, or a cradle. If you don't see the cradle, your car is not prewired. Most weren't.
I love the integration, but partly because I use an older phone that clips into the cradle. Not only does this save me the $400, but the integration charges the phone and uses the car's antenna and amplifier for better reception. I no-answer-forward that phone to my modern phone. But the Bluetooth integration works pretty well too. As I said, the voice activation (another clue if you already are wired -- no voice activation for your COMAND indicates no phone wiring) is pretty neat too. You can control all COMAND functions and is part of the phone installation.
Yes, it's expensive but it works so well that you don't feel totally ripped off. It's clearly a decision only you can make.
#44
What an owner can determine by looking at the small flap in the center console (the phone flip-up compartment) is whether the handsfree installation is present. If the floor is solid black, or has a "D" shaped flat cover, then the car is simply "prewired" and there is no handsfree option installed. If there is a raised "D" shaped connector, that is the contact plate to which the cradle, combo unit, or puck is mated, and it means the handsfree option is installed. Photos of the flip-up are in the phone bulletins, with and without the contact plate.
In addition to the "handsfree" installation, the owner must choose either a cradle for a plug-in phone, a Bluetooth/cradle combo unit for certain phones, or a straight Bluetooth puck; and then should use a compatible phone.
The information in the guide contains links so that each of these items can be researched and followed up.
I also prefer to stay with the original MB equipment, though some contributors are happy with 3rd party solutions.
#45
I think we're in agreement, except perhaps that I'm using "prewired" as many people (and dealers) do, to mean the installation of the the MHI and electronics. as oppposed to the more accurate (but less interesting) inclusion of the basic wiring yoke. The $1,500 installation is required for most cars.
#46
Imagine the buyer of an '07 or '08 who has paid for the "prewired" option - because it is an option in most cases now - expecting to be able to easily connect the phone - only to find he also needed the "handsfree" option. The forum is full of folks who are very confused and very angry over just that issue, and I don't blame them.
#47
By "uninteresting," I meant "not very useful." I agree that MB could increase customer satisfaction by being more candid about what you need for phone support, both before and after ordering. My understanding is that the $1,500 MHI "prewiring" surprise expense is no longer an issue with the W221 because voice control, electronics and MHI cradle are standard. Yes, you still need the puck for Bluetooth (now called a handsfree option), but it's a lot better situation than before. Is this not the case?
#48
#49
Yes, the dealers indeed use "prewired" incorrectly, and repeatedly sell people cars (used and new) that the buyer expects will be easily equipped with a cellphone - only to find that there is a very large additional expense. That's why the distinction is important - and should be interesting.
