Finally!! fixed my washer fluid reservior leak...
Old Jun 9, 2020 | 07:01 PM
  #51
aguevarra's Avatar
W220 (S430)
Leak is fixed!!
I followed houqoutwou suggestion using soft vacuum connectors.
I purchased the Dorman 47432 vacuum pack from O'Reilly's for $4.99. I'm guessing Vacu-Tite was bought out by Dorman. Same part number though.
I chose the vacuum adapter with the largest opening so that I can slip it over the hard plastic tube.
I ended up siphoning the coolant out of the tank so that I can move it and swing it out of the way. I also removed the washer reservoir so that I can get more room to work and avoid any scraped knuckles ;-)
It's a tight fit over the hard plastic piece but I added a little bit of WD40 to help slip it over the hose.
I added a zip tie to avoid any future possible leak.
Slipped the other end over the washer outlet and added another zip tie for good measure.
Old Feb 19, 2024 | 11:42 AM
  #52
jmacres's Avatar
02 S500
I'm going to be doing this fix myself soon. Auto zone part# 47430 is now $6.99 - Bidenomics
