Brake pad error warning sign on dashboard
Old Jul 28, 2008 | 04:32 AM
stomar08's Avatar
Mercedes W220 S320
For a month i have been driving my 2000 s320 with a brake pad wear error warning on my dashboard wat do i need to do to get this fixed, and how much money will it cost
Old Jul 28, 2008 | 04:46 AM
schwarz's Avatar
124, 140, 211, 220, 221, 996
i'm pretty sure you need to get your brake pads replaced.
i had the same thing last year and got it replaced at the dealership. cant remember how much it was though. where are you located?
Old Jul 28, 2008 | 06:54 AM
Saverino's Avatar
'07 S550 w/ AMG Package
I remember on my old 2006 S500, it cost around $600-700 to get them replaced. I'm not sure if it will for you though, because of your location, year, and model...
Old Jul 28, 2008 | 11:51 PM
stomar08's Avatar
Mercedes W220 S320
iam from Melbourne,Australia
Old Jul 29, 2008 | 12:41 AM
Benz5656's Avatar
SL500
Does anyone know how to turn this error off. I replaced my rotors and brake pads and sensors because the racing pads I had glazed over, so now i have to clear out that error and its been about a month now.
Old Jul 29, 2008 | 07:41 PM
kenstudios's Avatar
The error clears itself as soon as the sensors are replaced. If you have a bad sensor the error still exists.
Old Aug 4, 2008 | 03:46 PM
Jezza's Avatar
S430, SL500
The "brake lining wear" message just means the brake pad sensors have worn through. Whole job in the UK including OEM pads and sensors comes to around £100, so thats ~$200USD.
Not a big deal at all
Old Aug 8, 2008 | 05:28 PM
benz_addict's Avatar
V12TT
replaced brake pads and the sensor yesterday but the brake wear message is still there
Will replacing the sensor again fix this problem? Faulty sensor perhaps?
Old Aug 8, 2008 | 10:43 PM
sessayan's Avatar
2002 S430
Make sure your sensor is seated properly. I changed my own brakes and didnt seat the sensor properly and still had the error. Once I went back in to see what was going on, i found the problem.
The sense needs to be pushed in pretty deep.
