I know this is gonna hurt my wallet ..
2005 S55
Gotta love it when everything happens at once, makes life more interesting!
Let's see, my baby (2001 S500) is having issue and she'll be at the Dr's later today or tomorrow, but I don't like going in with no idea at all what it should cost and getting screwed (doubly). I tend to trust (most) of the people here so I'm hoping for some wisdom ..
New issue, instrument cluster .. backlight went out last night, flickered and went dark, but the gauges were all still working and I still had milage, etc .. then this morning driving to work it all went, no lights, mo MPH .. nothing. I'm assuming this means it's dead, what am I looking at cost wise? Irecall an instrument cluster recall, but I'm assuming it's just too late for that, no?
New issue #2, low oil pressure warning came up .. of course I'm having that addressed too. My question is, there's a humming starting at around 60mph and up .. I thought it was the back tires getting to the end of their life so I replaced them, but the humming persists. Could these two issues be connected?
Last and old issue .. left front "ball joint" (I'm trying to remember the diagnosis) is bad, throwing the car our of allignment and allowing about 4-5 inches of play if you wiggle the weel when the car is on a lift .. any idea of the cost here, and if I'm correct when I say "ball joint". It is fun to say ball joint, but I don't want to sound like the idiot I probably am when I say it!
All this said, she's an S500 with 122k miles .. still love her .. just want her fixed!
Thanks in advance!!
M
Thanks in advance!!
M
Thanks in advance!!
M
Thanks in advance!!
M
2005 S55
Here's a big thread. Posts 125 and 126 document the warranty.
https://mbworld.org/forums/s-class-w220/141872-instrument-cluster-recall-s-class.html
W220 S65 AMG
I got a notice saying I have to bring my car in because there is a recall on the cluster and they need to replace.
Problem is you might have to leave the car over night as they can not and will not order a cluster until they have your vehicle in their possesion.
2005 S500 4-Matic, 1978 450SL
There was a recall initiated, and many of us with certain VINS in the specific year groups got the recall letter. It applied to specific VIN ranges of '00-'02 and '04-'05 S-Classes and CL Classes. It meant replacing over 36,000 clusters in a short time (of course, stressing the supply of clusters). Under the recall, the cluster was replaced whether it malfunctioned or not.
Mercedes reconsidered the recall, and supplemented it with an extended warranty from 10 years from date of initial service on all W220 S and W215 CL Classes in the U.S. - regardless of the year or VIN. In this case, the cluster is replaced only if it fails, and the warranty covers virtually all of failures - not just the lighting problem at the root of the recall.
Some dealers are only aware of the recall and not the warranty extension. If they start telling an owner that the problem is not covered under the recall, tell the dealer to do his homework, and look up the extended warranty. Many of us were given letters, together with a sticker for our warranty booklet, concerning the extension.
2005 S55
Thanks for the info on the cluster .. I'm dropping her off at MB of Oakland tom.. the lady said she does not know if they have a cluster and they won't order one until they diagnose the issue, which is annoying.
She said there is an extended warranty that covers my year but can not say if this will fall under it, I think she's just not sure so I'll not argue it unless they try to say it's not covered.
Will get the oil change then too, hopefully that will fix the "humming" at higher speeds, which would be bad in it's own way because that would mean oil was very low ..
Taking her to a seperate place for the front end work, stealerships just cost too much
Be careful. That front end is attached to a very sophisticated suspension. I personally wouldn't let anyone but a dealer or specialist touch an Airmatic or ABC supsension. The typical frontend shop does a poor job in dialing in the alignment on these cars as well. And you can't be sure of the parts they use. I shudder at the thought of riding on second-rate control arms.
BMW E39
My car will be 10 years old next year (purchased 6/99). The original cluster is still working. I'm thinking about lying and telling them that my cluster goes out intermittently, thus insisting for MB to replace my cluster. Reason being is, I trust a cluster from a 2000 W220 will eventually bust.
Thoughts on my decision?
2005 S55
Anyone have feedback on All Merceces in Oakland? All the reviews I've read are very good.
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
I had a bolt kit put in my car with an alignment a while ago, to me it just drifted to the right a bit..Shortly After I, changed tires I took it back for them to checked the alignment again and they did ( for free ) drove it, and said all was fine..
To me it still drift to the right... So I went back a few weeks ago for something else and though I'd throw is a little complaint about my car drifting..
They (again) guaged my alignment and said it was perfect.. Then stated that Al of these cars tend to drift ever so slightly to the right.. Well.
I can say that my tires have outlasted ANY set I've had since the alignment so I know for a fact its correct.. I was still thinking something was wrong till I spoke to fellow member Newton About his S and he stated his does the same thing.
It's not a hard drift by any means I just never noticed it with any of my other benzs but this one..
To your point Whoover,,
Imagine if I had opted to go to my corner alignment shop...Oh boy... there is just no telling what I might be riding on after swapping Am parts just to try to correct something that doesn't need correcting. This was a technical issue that i would have only gotten resolved at the dealer level I am positive.
But later that day (~4PM), he called informing that they have put the new cluster and the car is ready for pickup.
When I got there, I asked the SA if he was able to reproduce the issue and he said he did not need to as several of his techs have been doing a lot of cluster warranty and is a "common problem".
sounds good to me .... new cluster ... couple new reading feature and couple missing (documented in other thread)
2005 S55
Funny, looking like it's time to swap out my S500 for an AMG one (S55) .. lots wrong with my girl, nothing critical but a lot of ticky tack stuff. Instead of putting more $$ into her I think it's time to step up with the big boys .. hopefully in a few months (or less?) I'll be back with pics .. hopefully!
BMW E39
Well my new SA was easy to deal with (she had great legs too), and went ahead and replaced my cluster. Nothing seems right with the new cluster though. The mileage is wrong (20k miles off), the speedometer ring seems dimmer, and the transmission and clock display is crooked. Hmm, I'm gonna go send it back.
IT seems that everyone that had this cluster replaced has had new issues with the new cluster or the job nationwide.. I wonder whats up with that??
How did the valve block replacement go on the Airmatic?
BMW E39
Great legs.. and bad service.... that's what made Hooters millions..LOL
The new cluster is really irritating me. It also has an annoying chime upon ignition now. On the plus side, I'm loving the realtime speed readout.
