IPOD connection DIY - Anyone???
Old Aug 14, 2008 | 02:18 AM
bklynjoker's Avatar
"OO" s430
Has anyone done a ipod connection to amp or radio on w220??? my tape is acting up - so if anyone did a DIY ipod please share.....thanks
Old Aug 14, 2008 | 09:50 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
It has been shared repeatedly. The search tool would have gotten you an answer pretty quickly.
https://mbworld.org/forums/audio-electronics/194660-gateway-500-most-o-good-unit-poor-documentation.html deals with the MOST bus version of the Gateway 500; you will need the D2B version, so be sure to read for the differences. The Gateway 500 is, in my view, the class act of the iPod installations.
You lack an AUX input to COMAND in your car, so you cannot use the Apple/Mercedes kit.
Search for MoBridge and DICE for alternatives to the Gateway 500.
Search for Harman-Kardon Drive+Play for an FM direct antenna lead connection with a display.
FM over the air solutions are cheap and awful; worse sound quality than you probably got from your tape.
Old Aug 14, 2008 | 09:54 AM
Thugs Bunny's Avatar
2004 S55
Skylaw,
You should have a voice recorder with that answer Welcome to the party bklynjoker.
Old Aug 21, 2008 | 07:07 PM
bklynjoker's Avatar
"OO" s430
i went to a local audio shop and he said he couldnt help me with any kits for the ipod on this car,he had a kit for a 99 S - he said if someone tells me they can do it, becarefull cause it may burn out the navi screen?
NOW- I was woundering using the cassette -
remove the wire from the cassette
open radio on top
splice wire on to sensor/contact area of tape deck
final connection to that contact, run wire down center and install done.
looking at that cassette for ipod, theres nothing to it except that center contact piece which touches the tapedeck contact - gives sound
What do you think? i really dont care about loosing the CD changer if anyone has ideas...
2000 S430
Old Aug 21, 2008 | 09:04 PM
Skylaw's Avatar
Now I understand your screen name.
Old Aug 22, 2008 | 02:02 AM
bklynjoker's Avatar
"OO" s430
lol im not scared of trying new ****... Why does it sound funny to you?
everyone talks about this gateway500 - doesnt that cost almost 500 dollars?? for an ipod - Fck that, i rather try the wire idea. if possible
Old Aug 22, 2008 | 09:17 AM
2004 S55
Joker,
Use the search function! Your tape idea will not work and will most likely destroy the tape deck.
Old Aug 23, 2008 | 08:58 AM
Skylaw's Avatar
Originally Posted by bklynjoker
... Why does it sound funny to you? - Fck that, i rather try the wire idea. if possible
It's funny because it is so obvious you have no idea at all what you are doing, and that you would try such a blatantly amateurish approach in a fine luxury car. The approach is more suited to an '84 Honda with a fart can.
Even a quick look at the extremely low-end cassette adapters would reveal the circuitry necessary so that the iPod output is converted to the proper input for the tape head. Even those don't just "connect the wires" directly to the tape head.
Try, and fry away!
