New Brakes Squeaking Very Loudly???
E90 N54 & W251
If it's a squeaking sound, that's usually attributed to lack of brake grease or shims. When you put the new pads on did you include the shims and did you grease them well before installing?
I installed my new brake pads 10,000km ago now I'm going to do the front rotors now. I will see if they make any squeaking noise. Well I'm going in my garage now to do my brakes
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
grease only lasts till it rains. Use anti squeal compound, ( Blue ) ir in my case I had a applied a small layer of hight temp orange silicone between the pad and the shim, then between the shim and the piston. or pad support for the other side.
grease works on the pins but it doesn't last long. I bought new hardware and my problem was solved.
'00 S-500, E-430S, '88 Mustang
I am having this same problem on my s 430
I am in mechanic school and have been taking the car appart every other day for three weeks tried greasing
The pins today it made the noise Evan worse !
Teacher thought it was rear rotor park brake problem took
Off the rear rotor and still can't find what's makeing it squeeling , some one help !!
