Hot and Cold?!?
Old Nov 13, 2008 | 03:52 PM
E43 S's Avatar
'00 S-500, E-430S, '88 Mustang
Hot and Cold?!?
Does anyone have any idea why when I put the heat on i my car...after a while it blows cold air????
Basically, if I set it to 80....or hot it blows hot air...the moment i go down to 78...75...72.....it starts to blow cold air again....so i bring it up to HI...........then its HOT....what gives?
Old Nov 13, 2008 | 04:20 PM
Television's Avatar
CL500 216
This will be the duo valve sticking,, plenty of post around to fix this
Old Nov 13, 2008 | 05:53 PM
illmeth0d's Avatar
2000 S430
mine does the same thing does anyone have a link to the diy , i couldnt find it in this w220 forum when i searched.
Old Nov 13, 2008 | 09:21 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Search "All Open Forums" using "duovalve" - you'll get plenty of writeups. Here's one on complete replacement for an E-Class - S-Class may be similar. https://mbworld.org/forums/showthrea...hlight=hot+air
Old Nov 14, 2008 | 03:11 PM
E43 S's Avatar
I think you are right on point....thank you very much, the part is cheap, labor is going to be a little bit .....
Old Nov 14, 2008 | 03:46 PM
ohlord's Avatar
First
run the onboard diagnostics.
http://www.eclassbenz.com/node/27
then punch in the values.
then check your coolant level
finally clean and repair the duo-valve after you test it.By following the diy repair procedure on benzworld.org W210 diy section.
Most times a simple firm drum like tap on the side of each valve with the handle of a screw driver will free up sticking duo-valves,without resorting to taking them apart.
http://www.autohausaz.com/search/pro...ontrol%20Valve
Far cheaper to repair or thunk on the side than spend $170 for a part that rarely fails and a simple cleaning resolves the issue.
ohlord
Old Nov 14, 2008 | 04:44 PM
E43 S's Avatar
ohlord
WHOA---Ohlord, I was debating emailing you, but Skylaw...was pretty informative, I will try your recommendation this weekend, Ill keep this updated of my results.
Thanx
Old Nov 14, 2008 | 05:02 PM
ohlord's Avatar
The diagnostics
may work on the S platform,I keep forgetting you have an S now
The d valve listed is the w210 one so autohausaz.com will quote one for the S class.In any case between the nice diy up above and a tap of the screw driver you should arrive at heat nirvana
Lock up your cars ,Brooklyn
http://www.benzworld.org/forums/w210...andalized.html
look what they did to a forum members car,the world is going nuts.
