S350 2004 with No navigation installed
Old Dec 4, 2008 | 06:07 AM
iatallah's Avatar
S350 2004
Smile S350 2004 with No navigation installed
Hi there, any body has experience if the car that originally came with no navigation can be modified to have this navigations , I have 2 buttons on the Command APS one for the Navi and the other for Maps, once I press it says Navigation device unavailable !
so is all what I need to install the device or I have to check also the antenna and the GPS cable !!!
thanks
Old Dec 4, 2008 | 07:27 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
thanks
That don;t make any sense I have only seen 1 W220 without nav and it was in another coutry.. Where do you live?
did you check to see if you have the NAv drive in the trunk?
perhaps its because you do not have a DVD loaded. Thats why it says unavailable?
Old Dec 4, 2008 | 09:38 AM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
He has to be from another county because here in USA the S350 came out in 2006. his is a 2004 , and I've seeing a few S350 around here and they all had NAVIGATION .
Old Dec 4, 2008 | 10:30 AM
iatallah's Avatar
S350 2004
Yes this car in Saudi Arabia
Hi , this car in Saudi Arabia , what I meant is that do all W220 accept the navigation if it is not originally installed in the car does the Command compatible to operate the navigation as long as the two buttons are there (Navi & Maps)?
thanks
Old Dec 4, 2008 | 11:56 AM
m4xm1l10n's Avatar
thanks
I would think so , because we have installed lots of Nav system on ML320 that wasn't equipped with Nav when new
Old Dec 5, 2008 | 01:56 AM
iatallah's Avatar
S350 2004
well, the car in Saudi Arabia.
I checked the trunk left area where the CD / Navigation should be installed and I found a sticker that has the below information
DAIMLER CHRYSLER
A220 690 1353/9C24
KORA LI CD DVD FDS
YAP28474/02 Q2
so what do you think ?
Should this label be the one that is placed on the DVD drive and the previous owner took it out before selling !!!
Old Dec 5, 2008 | 02:34 AM
donjuan45i's Avatar
S500
you local MB dealership should be able to tell your cars original equipment with you just providing them your VIN.
Old Dec 5, 2008 | 03:27 AM
my06clk's Avatar
DAIMLER CHRYSLER
A220 690 1353/9C24
KORA LI CD DVD FDS
YAP28474/02 Q2
S classes that don;t have nav dont have Comand. I'd say it was removed
Old Dec 5, 2008 | 09:58 AM
iatallah's Avatar
S350 2004
Anybody knows how many cables (connectors) are there for the Navigation DVD drive and how many for the CD chagner, I found 3 cables with connectors laid there ( 1 blue and 2 black )
Old Dec 10, 2008 | 07:00 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
The parts number you found there is obviously only the number of the lid for the CD-drive compartment, becaue the ...9C24 stands for a color code of the carpet and lining color. The CD-drive has normaly 3 wires and possibly a bus connection. This thing really smells kind of "fishy".
:-) Check EBAY maybe the pre owner sells the thing there???
Old Feb 17, 2009 | 01:02 AM
dandrew0's Avatar
S350 W220 MY04
No Navigation
You probably have the Navigation unit in the dash command unit. I also had a missing navigation command unit in the trunk. (2003 S350)
The dealer brought out another dash command unit the same as mine and identified a gyro symbol on the side. Sure enough once he inserted the right command nav CD , bingo it was away.
Old Aug 14, 2011 | 05:23 AM
gill finlandia's Avatar
navigation cd s350 (2004) ineed buy in Finland
Gill phone +358405147216
