Really weird climate control problem. HELP!
Old Dec 5, 2008 | 05:11 PM
benz_addict's Avatar
V12TT
After work got into the car which had been sitting for an hour or so started it up and temp set to 74 degrees F but wasn't blowing any air. I thought no problem it's normal it will blow air massively in 1-2 min like it usually does.
After 45 min of driving still didn't come on I'm freezing my *** off it's 23'F outside then it suddenly started blowing air like it should. Climate control works fine it's just the blower motor keeps delaying and comes on when it wants to and when it does it works fine...any thoughts?
Old Dec 5, 2008 | 06:47 PM
THR2008's Avatar
2000 S500
My car was doing that during the summer. It was the blower motor acting funny. My mechanic played with it hasn't happened since. Sometimes it sounds like a jet when its going out.
Old Dec 5, 2008 | 11:54 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Mine had a similar problem,except that after I shut down for about 60 seconds and re-started, the blower came back on. It was a bad blower control unit and blower motor - both replaced under warranty in October.
Old Dec 6, 2008 | 02:45 AM
V12TT
Do you know what your mechanic played around with?
Originally Posted by Skylaw
Mine had a similar problem,except that after I shut down for about 60 seconds and re-started, the blower came back on. It was a bad blower control unit and fan - both replaced under warranty in October.
So my blower module and the fan it self are on it's way out?
I tired that restarting method but didn't work for me I even re-started the car waiting 5 min or so. Hmm... time to fire up the WIS
Old Dec 6, 2008 | 08:42 AM
Skylaw's Avatar
It may be only the blower control unit - but the tech also found that my blower motor was overheating, and replaced that too.
Old Dec 6, 2008 | 05:46 PM
V12TT
It may be only the blower control unit - but the tech also found that my fan was overheating, and replaced that too.
where is the control unit located? On the fan itself? I'm planning to take it out and inspect it.. the fan I mean maybe I can check out the control unit too
Old Dec 6, 2008 | 06:23 PM
THR2008's Avatar
2000 S500
Some weird looking thing towards the front. I haven't had the problem again. It was before I figured I could do most of the work myself. I'm guessing it was the blower motor.
Old Dec 7, 2008 | 06:22 PM
V12TT
is that the blower motor regulator aka the control module? (my work in progress) Also can I order this from the parts department separately? It has the part number "A 230 821 02 51"
Old Jan 19, 2009 | 06:34 PM
V12TT
the blower motor finally gave out today... looks like I'll be spending 295+tax on a new regulator.
Old Jan 19, 2009 | 06:49 PM
Quadcammer's Avatar
96 and 08 911 turbos
Don't be silly.
www.parts.com
$195 plus shipping. You'll have it by thursday, latest.
Old Jan 19, 2009 | 06:53 PM
Quadcammer's Avatar
even better.
azautohaus.com has it for $145 with free shipping.
Enjoy the $150 cost savings.
Old Jan 19, 2009 | 08:03 PM
V12TT
Originally Posted by Oliverk
even better.
thanks!
Old Jan 19, 2009 | 11:52 PM
samvel1981's Avatar
W124 E320, w210 E420,W210 E55 AMG,W220 S430 (sold),W163 ML 55AMG
Smile
ebay $113.99 + $10.00 shiping
Enjoy the $171 cost savings
Old Jan 26, 2009 | 05:56 PM
V12TT
There is a new updated part number for the blower regulator. The old ones that go bad were made by BEHR, it's now replaced by BOSCH.
Dealer is asking $730 for the motor... yeah right! Further extensive cleaning of my blower motor solved the problem for now and everything is working like it should, but for how long?
Old Apr 26, 2010 | 04:37 PM
LAWYER2's Avatar
15' W222
Is there anyway to conclusively tell if its the blower motor? I have nothing blowing out of the vents no matter what setting
Old Aug 3, 2010 | 02:55 PM
rayk's Avatar
2022 s580
AC blower not working
I have a '04 s430. the blower moror stoped working,then after 5 min. it went back on. Now a month later it is not working completly. I read comments.
Can someone tell me where the blower motor an module is located, so I can take them out to inspect/replace them
thanks in advance for your help
Ray (I hope, some day I can help someone else)
Old Aug 3, 2010 | 03:22 PM
Quadcammer's Avatar
blower motor is under the passenger side dash. Remove the underdash panels and you should be able to locate it.
Old Aug 3, 2010 | 05:31 PM
rayk's Avatar
2022 s580
Thanks for the reply.
I pulled off the lower dash panel and cleaned off the plug from the controll unit to the motor(which had some corrosion on it).Pluged it back in and the blower motor works fine
Thanks Ray
Old Aug 5, 2010 | 06:50 PM
arod2303's Avatar
is this under the dash on the inside of the car? im having the same problem but i want to take a look at the blow motor before i take that drive to the dealer.
Old Aug 5, 2010 | 07:49 PM
arod2303's Avatar
found diy pictures and found the blow motor now my questions is who knows where i can get a cheap regulator? for a 2000 S500?
Old Aug 2, 2011 | 12:22 AM
hotrod318's Avatar
2000 S500 mercedes
Old Feb 11, 2012 | 06:36 PM
Jerry-'s Avatar
2004 S600 (V220.176)
Better heating in the back of the car
I have a funny problem with the 2004 S600, as the heating is generally working ok. However, the rear of the car gets better "treatment" than the front. It gets the heat first and earlier.
Shortly after the start, while the front blows warm the rear already blows hot, at the same temperature settings. When I switch on REST then it blows hot in the rear and warm in the front (whatever REST button I press).
That would indicate that the front heat exchanger is faulty, but then there are these moments when the front blows super hot. The windscreen heater always blows hot. In normal operation the front temperature is fine too. Would that be if the heat exchanger is bad?
So I figure that there is either an electronic malfunction or it is a feature setting. The first guy with the car had a driver and I can easily imagine that guy instructing the garage: "the rear of the cabin gets heats first".
How can I investigate the cause? How can I fix it?
Old Feb 11, 2012 | 11:44 PM
SFBIGBODY415's Avatar
2000 mercedes benz s430
probably the blower motor mine gave out cuz of water. when I took it out it was very wet always check you drain under the hood
Old Feb 13, 2012 | 12:12 PM
Jerry-'s Avatar
How many blower motors are there in the front? Is there a separate one left/right and a separate one for the windscreen heater?
Is it the same blower motor for heating and for cooling?
How many blower motors? This is because at least "one of the blower motors" works in my car.
Old Feb 13, 2012 | 02:44 PM
marktan's Avatar
2005 Mercedes S600, 2004 Mercedes E500 4-Matic, 2002 Mercedes C32 AMG, 2001 Trans-Am WS-6
I had a similar situation with the rear getting significantly hotter than the fronts, including the symptom of the front actually getting cooler at higher speeds on my 2005 S600. Assuming you've got the rear controls, there is a separate heater core for the front vents (including door pillars) and rear center/floor. I ended up flushing the coolant system and replacing the duo valve and aux heat pump (same assembly, against the firewall under the driver side windshield wiper) and it works like a charm now. Just something to consider looking at. Good luck.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
