20" Rims on s-class??
and are spinning dubs practical or is it gonna look outta place?
is the ride gonna be ok? or really bad?
the ride of the s430 with factory wheels is so smoooth! u cant feel the acceleration, it just flows
Spinning dubs are not practical in my opinion because for one main reason - they're heavy and for your S430, any additional weight will cause that "lack of power feeling" since your car is already heavy as it is.
Ride quality might be a little more rough but not that bad as you would think. However, the handling cause of the lower aspect ratio (i.e. side wall) will drastically improve. None of the tire shrieking as before with the stock tires.
If you go from stock 16" wheels up to 20" wheels, you will notice the extra weight. Unsprung weight does suck, but that's the price of vanity.
In any event, if the wheels are properly balanced and placed on the car with a torque wrench and not a power wrench, then the smoothless in the ride should remain close to the same.
I have had both of the mentioned tires on my S-class. I hope this helps.
i live in a really country area, the farest thing from a city with nice roads. I still want to show off the rims, 20" spinning seems not such a good idea? any suggestions?
I have seen 255/35ZR20's on an S-class before, they looked fine. Dunlop sp-9000's have a design that makes the tire have a lower profile look compared to Pirelli or yokohama tires.
295/30/20??
My 20's are much lighter than the stock 18's it came with.. AND the ride I hate to disappoint you is better. I don't even realize i'm rollin' 20's unless I look.
Times have changed... WHeels have gotten much better, and tires are made to compensate for exactly the items you stated...
You put 20's on an S with the right wheel tire set-up you can not be happier.
If you consider 20's vain, what would you consider purchasing a car with a sticker of +80K that is marketed 98% as a status symbol instead of a viable luxury Not vain right?
Apricotscrub..
PLEEEZE don't put spinners on your mercedes?? You did know those things are waaay out of style for cars right? or did you just get out of jail or a Coma?
Just find a nIce set of 20's and call it DAY....
295/30/20??
