Best ECU/TCU for S600 Biturbo
Can anyone tell me their stories? I am also worried that I tend to abuse and beat on my cars causing them to go into the shop alot and it may affect my warranty and/or they may reflash ECU/TCU.
This is probably the only performance mod that i am planning. I don't do any drag racing but alot of speeding and some street racing.
I have not taken the car to the track, so I don't know what she will do in the quarter mile, but I have competed on the street, occasionally. The only time I was defeated was by a super modded C5 Vette. When I got a chance to talk with him, he said he was surprised that I hung as close to him as I did. His car runs consistent 10.5's in the quarter mile. This is my second biturbo car tuned by them. I give them 2 thumbs up!
Does it make it harder to drive in the snow/rain? Are you ever worried that the mercedes dealer may reflash your ECU/TCU or your warranty claims may ever be rejected.
Rain is fine, don't try to floor it though. As soon as it starts making boost it will break loose in almost any gear and you might start shifting sideways.
Snow... well... not a good idea...
I took my car in to the dealer last month for an ABC issue. They fixed the problem with no hassles. I would think as long as the warranty issue has nothing to do with the ECU/TCU, you have no worries. And even if it does, there are laws to protect you.
Kleeman stage 2: 627 hp/772 lb ft torque
Renntech: 625 hp/775 lb ft torque
I've known about the Renntech chip for years, but Kleemann I hadn't heard of until I became involved on this site.
I've already purchased the Kleemann ECU for my S65 but haven't installed it yet as I wanted to get some good base-line dyno numbers and ET's before I made the change. I've already hit the dyno with it in stock trim and put down 530rwhp (no pick up for a trq reading). I'm headed to the track tonight to get some good idea of ET's.....next week I'll be putting in the ECU upgrade and heading back to the track for back-to-back comparisons and then back to the same dyno......that will tell the true story. Granted, you'll see better better results in the 600 vs. the 65, but this should give you some kind of idea of Kleemann's claims for additional power.
I chatted with Brandon at Kleemann several times before making the purchase.....sharp guy, very sharp. Felt very confident in purchasing from him- and he was willing to work with me on re-flash issues if the dealer were to ever set mine back to factory......and for $2500??? That was a no-brainer to me........to be confirmed as per above
I talked with my mechanic this morning and he was telling me that he has seen a transmission pop in a S600 from being stressed beyond its limits with one of these software upgrades.
How does RennTech add 100 ft-lbs to the S65? By removing the limiter. Does that sound like a good idea? Do they really know something the AMG engineers don't? Or maybe they're counting on the fact that most people aren't going to use all that torque very often. But if you do, what do you think is going to happen?
The good news is that the S600 mods don't exceed the 738 limit by as much as the S65 mods do, because the 65 already starts out there. But you're playing Russian roulette with your power train, and this is what your mechanic is trying to tell you.
CHunter323232
Whoover & Gondon: Cory from Kleemann claims the limit is 1100 NM (811 lb/ft.).
chunter: I wouldn't trust those chips.
Others have bought this chip for "****s and giggles" and here is what they found... Here is your SLR chip:
The W5A900 722.649 transmission is used in the 600s, 65/65BS and the Maybach 57S/62S. The 55s use the W5A580 722.643.
If you blow it the part is A240-270-05-00 and Mercedes lists it for $6,470.00!
Well, my transmission is not destroyed yet. Here's what happens. The tranny will disengage if I stress it way too much. If I turn off traction control, and nail the throttle from a dead stop, and let it try to shift to second, Boom, no second. I have to turn the car off, and restart it. Then it's fine. Sets off a transmission code. I cant remember what one, I'll ask my mechanic. It happened once when I was doing about 50 and dropped the hammer. But that was only once and temperatures were about 50 degrees. The engine was definitely feeling it's oats that day. I will bring it back to RENNtech when I get some spare time. They are very close to me. It's just finding the time and dropping it off.
When you go back to Renntech if you are able to ask them if they removed the protection features built into the programming to reduce the risk of shock loads between shifts (such as torque overload). Kleemann claims they don't remove them.
oxygen: $6470 doesn't seem that expensive... but I bet it costs a lot in labor to install.
http://www.kleemann.dk/site/75AA8CA3...1E6D6E94AF.htm
whoover: Thanks for the link... I am going to ask Kleemann about it.
