My stock S65 goes 11.59@122...movies/time slips inside.
Old Jan 27, 2009 | 09:16 PM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
Its a great comparison of a stock S600 vs S65 to see my S600 stock on drag radials vs this S65. His run of 11.59@122 is just incredible. My best run stock on drag radials is 11.97@114.7 with a 1.75 60'. You can see the hp difference and the potential there. I bet the AMG tune of the S65 is more aggressive but the larger displacement (5.5 vs 6.0) and the 65 series minor exhaust and intercooler circuit upgrades help as well. Good luck with the Kleemann tune and I hope it gives you a great performance increase.
Old Jan 28, 2009 | 04:16 PM
Busa196's Avatar
2018 S63, lowered
That's good info Stephen, my brother (housclass) and I plan on bolting up my DR's to his 600 and seeing how it does. It'll be interesting to compare the 2 of you .
Old Jan 29, 2009 | 01:46 AM
razb0yn1k23's Avatar
a few AMGs
Damn nice, my s55 looks like **** next to this lmaoo.
Old Jan 29, 2009 | 07:31 PM
over the edge's Avatar
SL65
Originally Posted by Busa196
I ran it in dyno mode.....no ESP at all. That's the only way to get a good burnout and ET, IMO.
I ran the car on Mickey Thompson ET Streets 265/40/18......traction was no problem. As far as "launch technique" is concerned, very simple......I stood on the brake as hard as I could and power braked the car up to about 3k and then let go when I saw green. 3k is the point where the torque of the car overcomes the brakes and you can barely manage to hold it still......I thought I was going to physically "bend" the brake pedal from pushing on it so hard. MB bulids a solid car, no doubt about it
Has anyone run the 305 ET streets on stock 9.5" rims (SL55)? I realize the min width is supposed to be 10.0 but factory rims are usually a bit wider than listed. I doubt there would be any rubbing issue since its only 1cm wider on each side than a stock 285. Hoever I am a bit concerned since the et streets run a bit a larger overall (vs nittos which seem to run small).
Old Apr 19, 2009 | 11:39 PM
Fastgreek's Avatar
2005 SL55 2022 GLE350
i gotta get one of these........
