Question about offset
Old Jan 23, 2009 | 09:08 PM
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
Hey guys i lowered my car more and now on a highway i hear how my rear archs scrathing tires, i heard about offsets, but really dont know what is it, and how much it would cost.
Old Jan 23, 2009 | 10:10 PM
ohlord's Avatar
offset is
the amount of off the center line of the rim the mounting hub moves the rim either in or out towards the fenders.All you can do now since you need to move the rim in(and you can't do that) is have a shop that rolls fenders perform that procedure.And that will give you more room away from the fenders.
If it is the fender contacting the top of the tires,you need to change ride height(not cool) or change rims to get the proper offset(ET)
ohlord
a good link to learn more.
http://www.1010tires.com/tech.asp
Old Jan 25, 2009 | 01:16 AM
Arlen777's Avatar
ohlord
Thats what i was affraid of cause guy in the shop told me that my fenders already rolled, what if i put less wide tires i got 285 in the back now what if i put 255??
Old Jan 25, 2009 | 01:28 AM
benz_addict's Avatar
V12TT
I got 255/40 in the rear on my 19s and no rubbing...
Old Jan 25, 2009 | 01:58 AM
Arlen777's Avatar
Can you make a close pic of ur rear wheel so i can c it, cause my rear tire and arch are at the same level
Old Jan 25, 2009 | 04:03 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
If the offset is not good it doesn't matter about the tires if your car is lowered, YOu still may rub.. 275 is the sure bet for the rear if you are running 20's and don't want to rub.285's will almost always rub if you are lowered regardless to your offset.
Old Jan 25, 2009 | 04:53 PM
Arlen777's Avatar
How low is urs
Old Jan 25, 2009 | 08:12 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
i run 275/30/20 and 245/45/20 in front during summer! no rubbing very low...
Old Jan 28, 2009 | 03:49 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
your tire is prob rubbing against that area where the bumper and fender meet. There is a large edge that can rub tire when the suspension travel upward. I had to grind that edge off my car.
Im running 20x9.5 +38 with 255-35-20. with a 5mm spacer to clear the rear brake caliper. so it is more like a +33 offset.
Old Jan 28, 2009 | 06:00 PM
stevedel's Avatar
W220
if you're rubbing the oustide of your wheel against the inside of your fender, the only way you'll eliminate the problem is to raise the car or to stretch a more narrow tire. keep in mind that the same offset will have a varied backspacing for different width wheels.
Old Jan 28, 2009 | 11:05 PM
da boss's Avatar
2002 s500 sport package
no rubbing
Old Jan 28, 2009 | 11:35 PM
Arlen777's Avatar
I am lost now, so how do i change offset, is it something about changing rims or something changing with my car?
Old Jan 28, 2009 | 11:59 PM
S5504U2NV's Avatar
2007 S550
Offset is how rim is manufactured which keeps it flush. If you're too low when the car lowers at 80 then you'll scrub. BTW ohlords post is what offset is.
Old Jan 29, 2009 | 12:11 AM
Arlen777's Avatar
now i get it, BTW my car rub even i drive 20 and rub more when i drive 80, also there is nothing wrong about posting what offset is, this forum exist for it, anyways thanks for explanation
Old Jan 29, 2009 | 10:29 AM
my06clk's Avatar
BOttom line is: you can't just throw any wheel and tire on your car and expect it to work if you are going to lower it.
A 285 is too much tire for the rear first of all, an 9.5's work much better than 10.5 DEPENDING on the wheel offset, the tire size ou choose, AND whether or not you are lowered.
It sounds like you need to change wheels or get rid of theise 285 tires if you want your problem to go away.
Old Jan 29, 2009 | 11:47 PM
Arlen777's Avatar
Yeap i wanted to get rid of it and get 20's with correct offset, but on monday one f***ing a**hole booted my car, so i paid 260$ for my parking tickets and 200$ only to unboot it. So, new wheels will have to wait
