I am tired of my rear wheels rubbing...
Old Feb 25, 2009 | 10:06 PM
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
Im tired of my rear wheels rubbing arcs, i wanted to get 2 new rear wheels, i dont know anything about offset etc. So whats ur suggestions, what offset should i get and which tire size, and if there is any other specs i should know about?
Also if you know any good place where i can order them
Old Feb 25, 2009 | 10:18 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
ET42 FRONT & ET44 REAR 245/35/20 AND 275/30/20 Should do for you .
Old Feb 25, 2009 | 10:19 PM
m4xm1l10n's Avatar
ET42 FRONT & ET44 REAR 245/35/20 AND 275/30/20 Should do for you !!! Also read this thread
https://mbworld.org/forums/s-class-w...w-set-20s.html
Old Feb 26, 2009 | 12:40 AM
Arlen777's Avatar
I got 19s is it gonna b different, what about width for rear
Old Feb 26, 2009 | 12:48 AM
m4xm1l10n's Avatar
what do you have now? should be 275/35/19
Old Feb 26, 2009 | 01:09 AM
Arlen777's Avatar
Now i have 19s, front 8.5 rear 9.5 (both with wrong offset) rear 285/30/19
Old Feb 26, 2009 | 01:20 AM
Arlen777's Avatar
Do you know any website where i can get it
Old Feb 26, 2009 | 12:15 PM
m4xm1l10n's Avatar
Well first i need to know what is the off set , remove the rear wheels and look at the numbers on the inside of the wheels . 285/30/19 belongs on SL CLS , most likely you rear wheels off set must be ET 35 AND LOWER Possible . LOWER the number more chance of rubbing . I had a CLS 18" WITH 285/35/18 AT ET28 OFF SET on the rear , it rubbed like a ******* , my stock 18" is FRONT 42 AND REAR 44
Old Feb 26, 2009 | 01:39 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Check his earlier posts.. The Wheels are wrong and those 285 tires make it worse.. Arlen alreadys knows this.. I guess it was just tsupposed to go away over time.
BTW.
Depending on the Wheel design, width, and lip if it applies, 42 to 46 is the only good offset for the rear running 19's or 20's on an S class. 285 tires work in some cases but only where the ofset is maximum like an ET44 or Et46. Otherwise 275 is the Actual correct size for this car!!.
Those that want to keep trying different things well, more power to you but don't complain when you have no letters on your sidewall because you can;t seem to understand that you just simply can't "make" a certain wheel/tire setup work just because you think it looks cool.
Every wheel out there won;t work on this car no matter how it looks. Learn to accept that an move on to something that works.. it's the best way..
Research before you buy!!!! IF the nice salesman swears up an down it will work, make him or her put it in writing that they will take them back for full refund of they don't.
Old Feb 26, 2009 | 05:20 PM
Arlen777's Avatar
BTW.
So, if i get 19 with offfset between 42 and 46 with correct tire size and lower my car little bit more it wont rub right?
i want to go lower than this for 1 more inch
Old Feb 26, 2009 | 06:34 PM
baugh's Avatar
s320
I know your running 19's not 20's like me, but others have already pointed out in my thread that 285 tyres on an s-class are really wide, and you are gonna have probs.
Look at your pic it looks like the tyres are rubbing on the top of the arch, with it touching when ever you go over a bump in the road.
There are loads of room inside the s-class arch's to go really low, however the rim AND tyre has to fit inside the arch, so when it goes down it doesnt rub.
The first thing you need to do is take the wheel off, find out your current offset, then plan a tyre from there.
Its all about the OFFSET. As I have found out.
Im running a 42offset on the back wheel, which others have pointed out to me is pushing it for a 10inch wide rim.
Get the offset then go from there.
Old Feb 26, 2009 | 08:41 PM
my06clk's Avatar
Yes and it will help you a lot to use the correct tire 275 not 285 if you want to tuck in the fendr well that much.
Old Feb 28, 2009 | 12:30 AM
Arlen777's Avatar
Thanks, i was trying to find exact pair of rims like mine, but couldn't find, so decided to go for 20's (dont wanna be teenager no more ), can you post some pics of ur car on 20 to see how low i could go.
Old Feb 28, 2009 | 01:19 AM
cheez80's Avatar
alternatively, it would be possible for you to shave or roll the fenders. i'm not terribly familiar with what you can do in the rear of the w220 to fit wheels, but rolling the fenders and perhaps doing a newspaper pull may allow you to run that wheel/tire combo.
Old Feb 28, 2009 | 11:27 AM
baugh's Avatar
s320
This is a pic on 20's
Dont be put off with it sitting high, its really low, I have the airmatic on here in this pic.
Am gonna black windows, turn airmatic off and get it on the proper 275/30/20 tyres and post some more pics once its finished.
Old Feb 28, 2009 | 02:36 PM
da boss's Avatar
2002 s500 sport package
No rubbing here.
Old Feb 28, 2009 | 08:13 PM
Arlen777's Avatar
Anybody knows online store, because i found wheels but couldnt find it whith 44 or 42 offset, also what size is hub bore on s-class? Also et44 and +44 same thing right?
here are the wheels i wanted
Old Mar 1, 2009 | 01:02 AM
my06clk's Avatar
Hub Bore is 66.56 an yes Et 44 an +44 is the same thing.
Old Mar 1, 2009 | 03:32 AM
benz_addict's Avatar
V12TT
just roll your fenders man. The rear wheels on my S used to rub too but I pulled the rear fenders and no rubbing now.
Old Mar 1, 2009 | 03:57 AM
Arlen777's Avatar
i would, i was at bodyshop they told me that my fenders already rolled
Old Mar 1, 2009 | 03:59 AM
Arlen777's Avatar
Thanks, where did you get your rims?
Old Mar 1, 2009 | 07:11 AM
baugh's Avatar
s320
20's on an ET44 would be fine. What is the rim width on that offset out of interest?
Old Mar 1, 2009 | 05:26 PM
my06clk's Avatar
ST4's from Tire Rack
Old Mar 1, 2009 | 08:55 PM
Arlen777's Avatar
what do you mean out of interest?
those are 8.5 width
Old Mar 1, 2009 | 09:09 PM
my06clk's Avatar
those are 8.5 width
Mine are staggered 8.5 Et44 front and 9.5 Et 46 rear they fit perfect.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
