Aftermarket air filters for S600
Old Feb 26, 2009 | 03:11 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Okay guys, Who makes one
I searched my favorite K/N and they don't even list one. Renntech/Evosport does not list one either? Does ANYBODY
Beuler, Beuler, Ferris Beuler
Thanks, and see yeah
Old Feb 26, 2009 | 03:14 PM
silver65's Avatar
2003 S600
BMC. Do an online search. You should be able to find them.
Old Feb 26, 2009 | 03:54 PM
Oxygen's Avatar
W220 S65 AMG
I can get you the BMC filters.. Please PM!
Old Feb 26, 2009 | 06:30 PM
wyatt earp's Avatar
2003 S430 Sport Package
Autohaus Arizona.
www.autohausaz.com
pair of Mann filters $45.93
Old Feb 26, 2009 | 09:02 PM
Oxygen's Avatar
W220 S65 AMG
Originally Posted by wyatt earp
Autohaus Arizona.
www.autohausaz.com
Those are the OEM filters, $45.93 is much cheaper than what the dealer charges.
Old Feb 27, 2009 | 08:54 AM
wyatt earp's Avatar
Yep, my dealer wanted over $150 to change out the filters when I had my last Service B done. I said "no thanks" and bought them from Autohaus for $35 shipped.
Old Mar 16, 2009 | 07:48 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Okay, so I received my BMC filters this weekend, and installed them.
THANKS OXYGEN
You only need a T25 torx fitting on a ratchet for speed. Take the top cover off, simply pull up.
Six T25 screws on each cover, remeber to loosen with a cross pattern so you do not warp the plastic top, or crak it
After removing the stock filters, I shopped vac out all of the fine debrie that had settled in the air boxes
Install the new BMC filters, on the top cover, they stick better and seal off the intake side easier if you do this guys, as opposed to simply putting them in the lower side of the air box.
tighten the screws hand tight, wola, your done.
I did notice a slight increase in turbo noise, which is a GOOD thing. And I did take out a auto C6, which is even a better thing
THANKS AGAIN OXYGEN
See yeah
Total time about 20 minutes, including cleaning up the engine covers
Old Mar 20, 2009 | 04:05 PM
makoie39's Avatar
E39
Hi, how do you take off the main plastic cover?
My dad has a '04 S430 and I always wanted to check/replace the airfilter but cant figure how to take off the main plastic cover. I can easily take off the front plastic cover but always having a hard time on figuring on how to take off the main one. I just dont want to break it if I forced it or pry it.
Thanks in Advance..
Old Mar 22, 2009 | 01:33 PM
GARY JAVO's Avatar
2003 S-600
Pull up on the front of the large main cover, then slide it forward (towards the front bumper).
