02 S500 - Need to restore original ride height, HELP.
Old Apr 26, 2009 | 12:37 AM
notoriousALE's Avatar
02 S500 02 X5
Guys,
I lowered my S500 using the simple washer method and altering the positioning of rear sliding mechanism. The rear tire wear on the inside edge has been terrible and I just had to put new EXPENSIVE shoes on the S. I now want to put the car back to its original height setting.
Front is easy, just remove the washers. I'm having difficulty with the rear. Rather than eyeball the height, move the slider mechanism accordingly, etc. I figured somebody would know what the factory height is or what the slider bar setting is from the factory.
Can someone help me with this? I am running 18" AMGs on all four corners.
THANKS!
Old Apr 27, 2009 | 08:24 PM
benz_addict's Avatar
V12TT
I would also like to know the original ride height of the S500, can someone measure from the ground to fender with a measuring tape? Perhaps I should sneak to my neighbors S-Class at night and measure it... but that might look wrong
Old Apr 27, 2009 | 08:39 PM
02 S500 02 X5
Great idea actually, ask them if it would be ok and just measure theirs.
Please report back asap!
Old Apr 28, 2009 | 12:10 PM
Oxygen's Avatar
W220 S65 AMG
I have a bone stock '00 S500 here at the shop if that helps?
Old Apr 28, 2009 | 12:20 PM
02 S500 02 X5
Smile Measure it!!
There is the slider above the rear diff, and if possible take a pic of it, or read its position, ie what tick mark a it set to? Otherwise measure from the ground to the wheel housing lip center.
Old Apr 28, 2009 | 01:09 PM
Oxygen's Avatar
W220 S65 AMG
I don't have it up on a lift yet, but will soon.
Measuring from the ground to the fender, it was 27.5 exactly in the front and 28.5 exactly in the back.
Old Apr 28, 2009 | 06:19 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Wassuppp Notorious!! Long time...
I think the your magic number is 15" to 15.25" from the center of the hub
or 24" to 24.25" from the ground if you have the correct size tires. This is for the rear.
You can't go by the setting of someone elses slider because it adjusts a transducer, and the mv reading my be slightly different between the cars.
The easier way is to raise the car fully with no washers in the front and observe the following..
You should have .25 to .5 difference between the measurement of the front and rear wheels because of the arch difference. Front being higher. adjust the rear to this abount and put the car back to normal height and your number should be close to 15.25
Old Apr 29, 2009 | 06:10 PM
02 S500 02 X5
Ok. So raise it ALL the way up with the dash button after removing washers and try moving slider to achieve .25" diff in rear? Keep car fully raised entire time.
Old Apr 29, 2009 | 08:43 PM
V12TT
thanks oxygen and clk!
Old Apr 30, 2009 | 01:32 AM
my06clk's Avatar
Yes. YOu can put it back down after you get the height you want in the rear.
Remember you have to drive it down the street and back before taking ach measurement to make sure it has adjusted itself properly.
