Bloody squeaking brakes
Old May 10, 2009 | 10:31 AM
Quadcammer's Avatar
96 and 08 911 turbos
Will these damn things EVER stop squeaking? jesus is it annoying.
Brand new mb rotors up front with akebono ceramics. MB lubricant used on the pad backs, the bolt/slides and where the pads sit in the caliper brackets.
Same situation out back with the exception of EBC red pads.
Did my best to bed them in properly.
yet at light pedal application they squeal like a baby seal being clubbed.
Any other suggestions to get this crap to stop?
Old May 10, 2009 | 10:50 AM
AsianML's Avatar
2007 E63
Drive faster.
Old May 10, 2009 | 11:31 AM
Quadcammer's Avatar
wish I could.
And it only happens sometimes. Very annoying.
Old May 10, 2009 | 12:09 PM
comforta's Avatar
2003 S500 4MATIC
brakes
This is very annoying for me as well. My wife opens the door to the house when I pull up because the brakes make enough noise for her to hear from inside the house. This does not make sense to me.
Old May 10, 2009 | 01:40 PM
vmystikilv's Avatar
Range Rover
When you figure out a solution let me know. I have brand new brakes, all parts from mercedes and it squeaks, suspension moves slowly, it squeaks. I swear to ___ that my 740il back in the day was a quiter Sedan stnading still. But you know, with the doors closed. you dont hear crap and on the interstate it is the quietest machine I have ever drove on the road. Even less than and smoother than a Bentley Mulsanne S. Is kinda embarrsing though to pull up to some places sometimes and people are looking at you like WTF
Squeaks and noises may be annoying
But I love this _____- CAR
Old May 10, 2009 | 07:07 PM
Gondon's Avatar
02 S500 Sport
Oliver do the EBC and Akebono breaks have the same Break in procedure?
I heard you need to drive faster and break harder to warm up your breaks to stop the squeaks.
Old May 10, 2009 | 07:17 PM
RedG's Avatar
a g
Akebono brake pads are post-cured (pre-broken in), the EBC's are not. Though it is a good rule of thumb to follow prescribed brake break-in procedures. I always suggest at least 1 tank of fuel, extra braking distance, and the 2 second following rule should always apply.
Old May 10, 2009 | 07:50 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
He's right I have Akebono on both of my cars and simply no dust , brake feels smoother and a stronger stopping power that won't quit like the OEM Pads felt before .
Old May 11, 2009 | 01:02 AM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
i usually use the spray on brake quiet compound on back of the pad and all sides of the pad shim plates. No squeak problems at all on my ML and S. They both use the same front brake caliper.
Old May 11, 2009 | 12:24 PM
Adrianx's Avatar
2004 S500 4Matic
I have heard in cold temperature or sudden change of temperature makes the ceramic peds squeal?
Old May 11, 2009 | 01:03 PM
m4xm1l10n's Avatar
Well I haven't experienced that yet , and we had Temp. below 10 degrees here in RI
Old May 13, 2009 | 12:58 AM
RedG's Avatar
a g
Not always necessary, check what the recommendations from your brake pad manufacturer are. Akebono pads come with their own pad lubricants as do many others. Many Wagner brake pads have shims/backing plates built into the brake pad for the simple reason to prevent shim or backing plate failure (i.e. falling off).
That could be true of any brake pad ceramic or not. But ideally no brake pad should start to make excessive noise from temperature changes considering the brake pads already experience huge temperature changes from just simply stepping on the brake pedal.
Old May 13, 2009 | 08:23 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Okay here is EBC's bedding process from their site
use the brakes on a quiet and safe road 5-6 times at medium pressure bringing the car from 60mph to 10mph. Drive the vehicle for a few miles to allow the brakes to cool and repeat this procedure. During this final break in a brake odour will almost certainly appear and this is perfectly normal. This is known as green fade where the surface resins within the pad finally cure and burn off.
If you read the instructions, it will vary a little.
My own, squeak free bedding is as follows:
Change brakes and USE anti squeal greese please.
Go to an interstate, make 8-10, 50 to 10 mph fairly hard slow downs, caution DO NOT COME TO A COMPLETE STOP while doing this. The idea is to get the brakes VERY hot without fading them. Note: You WILL smell the brakes in the car during this procedure which is normal. This burns off ANY break in coating, and allows the brake material to get up to operating temprature to bake them, aka harden them. After you have made these passes, continue driving for atleast 10 miles WITHOUT using ANY braking, or as little as posiable, aka allow them to fully cool down. Drive the car home and allow to sit overnight. DONE. I have used this procedure with with ALL brake brands, and it works like a charm. It was an old racer trick at the track when changing out pads.
Note: For rear axle, use the energency brake while doing your slow downs, and reduce the speeds to 40-10. The rears CAN'T take as much heat as the fronts, aka smaller surface area. You will also need to do LESS slow downs with the rears 4-6. But same rules apply, and DON'T fade the rears, which is easily done at higher speeds while using the E brake.
Give it a shot.
See yeah
NEVER had any squealing after this I might ad.
