Break Lining Wear message doesnt go away!
so I thought it was the brake pads... i replaced the brake pads and got new sensors as well.
However, the message still doesnt go away... ?
What is wrong?
Thaat could work for oem pads also. if the sensors crush in the slightest amout, they will complete the citcuit that detects worn pad and give you a message.
On the w220 unplgging them does the trick. ( just as a test ).
On others like the ML the circuit has to be made to defeat signalization so they actually have to be shorted together.
Why don't you just spend 8 bucks on new sensors and insert them the right way? You could even plug them in before installing them and make sure they work then you will know that it was the insertion that made them bad.
One of the sensors are probably not pluged in or damaged
Good luck
I simply push it and held it in for a few seconds, and whola
PS: Mine is an 04, and this also worked on my TPS system when I change pressure for spirited driving
