2002 s500 problem
Old Oct 28, 2009 | 11:35 AM
mr.benzino's Avatar
03 MERCEDES BENZ S55 Amg
2002 s500 problem
A few months ago, I dropped off my car at Helms Bros. Mercedes benz for some repair do to the fact that water got into the car and messed up a few electronic components. The following parts listed below were changed. The soft door close assist was working at the time but now its not working. Who would be responsible for this? I did service the car at that pointas the trasmission flush brake flush and a full detailed job both the exterior and interior of the car my bill was crazy
a total of:5071
1.220-820-30-26 control unit 324.36
2.220-545-06-41 cable connec 111.18
3.220-820-31-42 electric motor 637.50
4.230-821-64-51 blower regulator 244.80
5.002-545-22-01 fuse box 94.76
6.032-545-84-32 transponder 324.36
7.210-830-10-18 pk dust filter 37.95
8.labor$2268.00
9.parts$2210.22
10.sales tax ny $413.42
Old Oct 28, 2009 | 11:48 AM
Quadcammer's Avatar
96 and 08 911 turbos
Thats a large bill.
Does the soft close not work on any door or just some?
You get water in the trunk?
Old Oct 28, 2009 | 12:12 PM
mr.benzino's Avatar
2002 s500 problem
It works sometimes on the passenger side front and back.
no I didnt get any water in the trunk
Old Oct 28, 2009 | 12:34 PM
Quadcammer's Avatar
Have you examined the fuse in the passenger side rear footwell?
Old Oct 28, 2009 | 01:04 PM
mr.benzino's Avatar
2002 s500 problem
Actually i have not checked that out.If I decide to what should I be looking for?
Old Oct 28, 2009 | 01:15 PM
Quadcammer's Avatar
Well pull the fuse and check to see if its blown. If not, plug it back in, and see if it still has the problem.
If that fixes the problem temporarily, its most likely due to a leak. Once the motor tries to pull a door closed, and can't it times out. Pulling the fuse resets the motor.
Old Oct 28, 2009 | 02:29 PM
mr.benzino's Avatar
2002 s500 problem
what number or color fuse am I looking for?Any help will be greatly appreciated.
Old Oct 28, 2009 | 04:11 PM
Quadcammer's Avatar
It should be a 20amp fuse, which is yellow.
Remove the footwell light on the passenger rear footwell, and you'll see the fuses. I couldn't tell you which it is off hand, but its at the end of a fuseblock color segment.
Old Oct 28, 2009 | 04:14 PM
mr.benzino's Avatar
2002 s500 problem
Alright cool will do that and let you know what happen's.
Old Oct 29, 2009 | 10:10 AM
mr.benzino's Avatar
2002 s500
I pull the fuse all look's well with the fuse but now, The doors are now working periodically I'm going to the dealer next week I'm getting very fustrated with This, I hope It's not an expensive fix.
