I need to change my transmission mount
I am looking for any guidance out there on how to physically changeout the tranny mount myself.
I purchased it new for $35 (OEM) and it arrived today.
Anyone that has tackled this, would really appreciate a few words of direction before I put her up on jack stands in the morning and have a go at it.
Thanks,
Art in San Jose
Here is how you can do it in 10 steps.
1. Remove 6 screws holding the rear plastic cover under the transmission and remove the cover.
2. Place a jack under the center of the transmission pan with a solid block of at least 10"x10" to spread the weight. You do not want to dent the transmission pan. I placed a 12"x12" composite (fiberglass) cutting board on top of my floor jack.
3. Jack it up until you make a firm contact with the bottom of the transmission pan and jack the transmission slightly up. I jacked up about 1/2" more.
4. You will see black steel plate right under where the transmission mount is. There are 6 large bolts holding the plate and and 2 small bolts attached to the bottom of the transmission mount on the plate. Remove 2 small bolts and set aside.
5. Then remove 6 bolts evenly and remove the black plate. The plate is heavier than it looks so be carefull handling it.
5. Once the transmission mount is exposed, you will see 2 bolts at the arms of the transmission mount attached to the transmission. Remove both bolts and take out the transmission mount.
6. Transmission mount arms are angled, make sure you put the new one with same orientation as the old one. One of the bolts has a ground lead with washer, make sure you include that when installing the new transmission mount and keep the bolts somewhat loose at this point.
7. Place the black steel plate over the 6 bolt holes and with all the holes centered, put in 2 bots at each corner without tightening them. Center the 2 small bolt holes with the holes at the bottom of the new transmission mount and install the 2 small bolts and tighten them.
8. While centering the holes at the black steel plate tighten the 2 large bolts at the corners and install and tighten the remaining 4 large bolts, securing the black steel plate in place.
9. Then go back up to the 2 bolts at the transmission mount arms and tighten them.
10. Install the plastic rear cover.
You're done and enjoy smooth driving again and let us know how it went.
Hope it helps.
I did the transmission mount just fine per the steps listed above. Thank you very much for the guidance. It took just under an hour, but I was slow and careful under there.
Then, I found a "free lance" MB mechanic on CL and hired him to do the engine mounts. Cost me $100 and took him less than 2 hours.
In the end, these three mounts (2 engine, 1 tranny) cost me all in:
$140 parts
$100 labor
$240 USD total.
My local stealership quote in writing: $2,211. Unreal. Many thanks to the contributors in this forum that helped me get up the courage to try part of the work myself, and to CL for letting me find a mobile, MB mechanic who works for cash!
Art in San Jose
EDIT: It seems the transmission change was somewhere around 2002 according to WIS. Anyway, my 2004 model had 8 bolts, two of which were a little tricky to get at. It's amazing what a new transmission mount will do for the smoothness of the car. $15 from autohausaz if I remember right. I wanted to pass along a picture of the old mount on the rright and the new one on the left. You can see where all of the rubber has torn away from the old one, very flexible and wasn't doing it's job.
Pretty much what is happening is what happens when you need a tranny mount replaced. I have a vibration between 35 and 40 mph driving at normal speed starting out after a stop. If i get on it starting out there is no vibration. My mechanic says it has to do with alignment and torque.
Thanks for the reply. It's nice to get comments or replys to posts it helps greatly.
knowledge of the process-except how much fluid to put back, and how to put it in,
I have no dip stick or dip stick tub on my Benz to refill with I think? Anyone know
about this?
My S600 has a dipstick tube but no dipstick.
There's a plastic cap on the tube which you have to break to remove.
I bought a dipstick on eBay for around $20 and I bought a few of the plastic caps from an online euro parts store.
