BAS ABS warning after carwash...
The ABS module is new according to my VMI, as are most of the brake components. I would assume that one of the ABS sensors got wet, but is this common? Rather odd... Anyway, I keyed off and re-keyed it, after turning the wheel full travel, and no warning...
I don't mind when stuff breaks, because that means its fun time in the garage for me, but intermittant stuff? Grrrrr.
Anyone else?
Turned out it was oxidation on the computer's circuit board that turned up all those messages. Once I took it out, dried it and put it back, everything went away.
Since you don't mind looking in, you may want to open the passenger side fuse box under the hood and inspect the transmission computer.
My issue occurred also after a car wash, I was sorry that I did not open and dried the computer until a week after this happened, as by then, half of the board was oxidized. I had to clean it with alcohol and dry it up, after which everything went back to normal, my car went out of limp mode, all messages disappeared for good.
At the time this happened, I already made some phone calls and found used computers on several junkyards ranging from 130-250 USD.
Good luck,
Alex.
Alkemist had some very good suggestions that may be more likely than the battery.
Anyone else?
So YES these sensors have terrible design. They malfunction once every year and kill all the security and safety of your vehicle.
The second link - http://www.benzworld.org/forums/w220...ttery-die.html - works just fine.
