Help!!! Car won't go when you step on the gas!!!
Hi everybody, new to the forum. My issue is when I release the brakes and the car starts moving when I step on the gas there's no response.
Would it be the throttle actuator or most likely the pedal replacement? Any help would be appreciated.
CL 600 '00 5.8L V12
Buy a cheap ODB scanner and check/verify the throttle pedal position with the actual position.
Also, when you replace it, replace it with a Febi Bilstein (https://www.daparto.nl/onderdeel-zoe...Bilstein/37963)
Mercedes part number is: A2203000104
This is one of the very few W220 problems where just throwing a new part on is a reasonable thing to do. Pedal failure is very common.
