'03 S600 dragstrip results
Old Mar 31, 2003 | 11:49 PM
  #51
brianhn1's Avatar
into things
OH MAN!!! sub-11 second quarter mile run, thats crazy!!!
I would love to get a hold of that sleeper :p
Excellent job Ben Treynor!!!
I wonder if you could get a video drag racing from inside your RENNTech S600... That would be sweet to see.
Old Apr 1, 2003 | 12:55 AM
  #52
benznut's Avatar
The brakes of the newest S600 will not be cleared by 17in wheels. Mercedes has stated that the reason they had to use 18s as standard on their V12s was because the brakes got too huge.
Old Apr 1, 2003 | 08:02 AM
  #53
pocholin's Avatar
Volvo V90 CC
Originally posted by davepl
As for the ABC, just pull the connector, its a black two-wire connector on a pump (on the accessory belt) on the driver's side of the engine. I pulled mine tonight to see what the ride was like (not a heck of a lot different, but noticeable).
- Dave
For those of us that are ignorant to the ABC plug, would you care to explain? please :o
Old Apr 1, 2003 | 01:43 PM
  #54
davepl's Avatar
It's a two-wire black connector that connects to the ABC pump, and is easily accessible on the CL600, at least. If you pull it the ABC system will not operate, but you can plug it back in at your convenience.
Old Apr 1, 2003 | 02:03 PM
  #55
pocholin's Avatar
Volvo V90 CC
Question
That is all very good, but what is the ABC System? What does it do?
Old Apr 1, 2003 | 07:37 PM
  #56
vraa's Avatar
Active Body Control, in our SL my dad loves taking hairpin turns at killer speeds, that results in a HELLUVA LOT body roll when the ABC is off, ABC on? No body roll, period.
Old Apr 1, 2003 | 08:19 PM
  #57
awiner's Avatar
2003 CL55 AMG
Active Body Control (ABC) ABC, a true active suspension system, utilizes a coil spring and an electronically controlled hydraulic cylinder in series, plus a separate gas-pressurized shock absorber at each wheel. Using a total system pressure of up to 2,900 psi, ABC continually adjusts each wheel's suspension to counteract vibration, pitch, dive, squat and roll. ABC also provides automatic 4-wheel level control, driver-selectable ride height and automatic lowering at higher speeds. Driver-selectable Sport mode virtually eliminates body roll for even flatter cornering and sharper handling response.
Old Apr 1, 2003 | 09:11 PM
  #58
pocholin's Avatar
Volvo V90 CC
Wow, cool! i want that too!
