Possibly buying an s500
I currently own a 2000 Infiniti q45. I absolutely love this car, and especially how little maintenance it requires. The parts may be expensive but I service it myself and the last 110k have cost me naught more than a battery and routine items.
At the time, I considered between the q and a 2001 s600. The cost of the maintaining the v12 scared me out of it.
Now, my car is wearing thin (180k) and requires about 4k worth of parts to bring to as-new condition. I'll probably only get 3-4k for her (if that, but it is PRISTINE).
I'm considering trading her in and picking up a 2002 s500 that a guy I know has on his lot.
I really have been one of the "stay away from german cars due to silly services and expensive parts" people all my life, always owning japanese or inexpensive to fix American.
I think the price is about 13-14. I'm really unsure as to how good of a choice this car is. I want a "big brother" to my Q - the S seems to be a perfect fit.
What should I look for? I am a very competent shadetree mechanic that is not scared to learn and get dirty.
The only reason I can own nicer used cars than my friends is because I can afford to fix them myself, offsetting the high parts cost. If this is too high, as a young father I need to be reasonable and slowly put that same money into my Q, which will probably run for another 150k if I needed her to.
Any input is highly valuable and thanks for the read!
I did browse through the topic, however it seems to be organized along the lines of frequent services.
Problem for me is the specificity of the services listed are already alien to me.
Every car has their nuances, such as the fgy33 q45's tendency to have bad coilpacks, or for the A/C compressor to fail at 170k without lubrication, or for earlier q45's and their plastic chain guides. It seems that thread is a great resource for people who own the car and are having problems, but doesn't seem too helpful for those clueless to the car or it's subtleties.
I understand suspension (depending on equipment) can be a nightmare with s500's.
I don't really trust the guy I'm buying the car from, but I trust my analysis if I know what to look for. That topic leaves me fairly clueless.
Does anyone have any real-world reliability for the long term for a similar car? w140 s500 over 100k?
For instance, I can tell you the fgy33 q45 is a bulletproof car. Very few things fail when fluids are changed and pads are good. A car I would recommend to anyone concerned with parts cost.
On the other hand, I would not recommend an infiniti j30, as the transmissions are weak and will fail prematurely. The seats also crack and age quickly.
Owners have reported costs of $3.5K to $11K depending how extensive the damage was on their ABC systems. Some owners who mechanically capable have been do this at a fraction of cost.
These cars require a Service A and B. Both are mostly oil and filter change, dealers charge $200-400 but you can do it yourself at $50 or so. The service interval is approximately every 10K miles. Spark Plug changes every 100K miles.
Bottom line is that, these cars are rather expensive to maintain if anything goes wrong with them and an extended warranty is highly recommended.
If you have any specific questions, please ask, people here are generally very helpful but it is difficult to answer a general question.
Good luck with your new car purchase.
That's just it - not sure if there will be a new car purchase! If I can justify it financially, then so be it.
I am not afraid of doing any of this work myself, I have most tools from valve adjusters to spring clamps and everything in between, and surely have the desire to learn a new car (manufacturer!).
http://www.autofind.com/dealer/detai...G75J3YA057261/
Not sure if I'll get THIS one, looking closer. 109k miles on it for $15k. My car is $0k with 180k. Can't quite justify that one. However, one in better condition or at a lower price is in the running.
I'm also somewhat torn, worrying about regretting the s500 instead of the s600. Aside from 1/2 more engine to maintain, is the vehicle otherwise the same? I.e., no "rare" or "exotic" system on the s600 that would break the bank? From Hondas to my Q45, I perform all of my own services.
I am not scared of maintaining a v12 by mysel or the costs involved, but don't want to sign onto a car with a part that will cost $3k that I could avoid with an s500.
to drive the S500 and have a personal assistant that manages the ownership of your S600.im not kidding at all,when it comes to a major repair it will cost you thousands every time.this forum is as important to owning one of these cars as the fobs used to start them.
The parts cost is my concern; labor will be free or hopefully rare.
For instance, when you say engine repair, on my Q it's about $700 for a dealer to replace your knock sensors. The KS's are about a hundred each, which is good money saved when done yourself.
Those coilpacks fail frequently or something?
Plugs and coils on a v12 is a 4 figure job just in parts. As many have said, you really dont want a 600 if it doesnt have an extended warranty. the FIRST repair will more than pay for a warranty cost.
The Airmatic is much cheaper to fix/service than the ABC, but parts alone (not labor) will run $1000+ for Airmatic rebuild and $3k++++ for ABC.
I say this because these are all things I have to do to my Q now (some for a second time).
I am not accustomed to maintaining a 4 cylinder civic, so hopefully it won't be TOO much of a stretch.
Since you're getting a feeler for the W220 I'd say the newer vehicle you can get the better, not only because it is newer (duh!) but because reliability sharpened up on these cars throughout the life of the model and also there was a facelift in 2003. Better COMAND system and some subtle bodystyle changes.
The prices of these vehicles have dropped so precipitously it isn't much extra $$$ outlay to step up from a bad, early W220 (like the one you linked up thread) to one that might serve you well for some time to come, a 2004 or newer. $15k for a bare bones 2000 S500 w/100,000+ miles on it is ridiculous! My father sold his '00 S500 for not much more than that 7 YEARS AGO!!
If you want a 600 getting a 2003 or newer is a no brainer. For me a decent warranty was a must, I got a Chrysler 5yrs/70,000 miles warranty on my S600 for $3220 a few months back. I'm sure that will pay for itself during my tenure and the piece of mind alone makes it a great buy.
Electrical issues. Also 2000 was the first batch of the W220s to hit the US and are the least reliable. My father had one and junked it, he hasn't owned a Mercedes since on the basis of that.
An s500 is probably a better idea, just for initial cost.
As I said, perhaps this isn't the right time for me. I'm damn near certain it's the right car, but perhaps not the right time. If the basic only way that I can guaranteed have a good time with this car is to spend at least 30k, then it's probably not a great idea. If I can find one from 15-22, then I'd consider it.
I realize that's cheap, but I also realize they do exist at that price point for 3rd owners around 100k.
Thanks for your help folks very good to hear from actual owners.
You've just got to get a pre-purchase inspection done, preferably at a Mercedes dealer since they'll be most familiar with Airmatic and ABC which are the big $$$ items on these cars if they go wrong.
I don't know if this link will work but on cars.com there are currently 37 S500s from 2003-2006 between $15,000 and $20,000. Hell, there's even a 200 S600 w/69,000 miles for $18,000
http://www.cars.com/for-sale/searchr...MENT&pgId=2102
IMO I would not put any money into the Q. If anything, he could sell his current Q, then get a lowmileage replacement one for just a few K more if he doesnt get the benz
Sadly, I get that all the time about my Q - What kind of car is that, a Lexus? I prefer Infiniti to Lexus, especially from a serviceability standpoint.
I have to say, this may not be an s500, but it was intended to directly compete with it and does have a 300hp RWD V8. It was sold for over $50k. It truly is an underappreciated car! Treated me well and I'd buy one again, if they new ones weren't so ugly.
That cars.com link is enticing though - definitely think I might go test drive one next week.
Thanks again for the input folks.
The Engine and transmission is pretty bulletproof as long as the services are performed.
On the Engine the CPS (Crank and Cam position sensor) One sits in front of engine the other sits in back before the transmission, its is an easy fix.
As other posters eluded it is the airmatic that fails, but with all the information here and Arnott's it is possible as a DIY and if you don't have star diag you can bring it to dealer or other options.
I have had virtually no problem with mine for 9 years and 108K miles, I did have to replace the airmatic relay (another cheap item). I never even did the top seal for my airmatic shocks I used some sealing fluid. At 108K miles my S430 still ran like the day I bought it, unfortunately it was totalled. Brakes/rotors are quite easy. Never replaced an engine or transmission mount. Alternator failed once covered by recall. I felt like my S430 could go another 100K miles. The materials that MB uses for Interiors hold up very well. I loved my S so much that when it was totalled I replaced it with another S but this time it had ABC.
Even with 2 of my cars having ABC I have been very fortunate ..knock on wood. I am also one of those people that immediately takes care of minor issues before they turn major. I only buy the correct fluid.
All in all I have had little issues not just with My S but also on my SL and ML.
One thing you can never get from another car is the smile you get and the secure feeling when you are driving an S class. Good luck and get it..we only live once and the experience you get from it is up to you. Just make sure you really check it out and don't rush. There is always a good deal if you look.
