Compressed air is leaking from the bottom of my front right strut (not from top seal)
S500 Airmatic right front strut is heard even while driving over speed bumps. The compressor constantly compensates for lost pressure. Higher ride option does not function correctly due to this, however warnig messages only if my car sits for 10+ hrs and front right drops low enough to trigger warning.
How do they rebuild those struts. Where is the air actually coming out and what can I do about it. I fixed the tops DIY method and they still hold;
Alternatively, I will order replacement one Monday have place set.
Thank you vey much.
I don't know if it is supposed to separate when the wheel is dropped like this. You see, when I inspected the other side (where the strut seems perfectly fine) the rubber did not separate from the strut and held on tightly. I tried pulling it off but did not apply excessive force not mess it up, so it stays on.
Second place is separation of the rubber ring from the actual strut column like you mentioned. Looks like once the separation starts there is no way you can squeeze it back in and secure it - too much pressure applied by Airmatic. You can see separation in this picture:
The other side looks def. much better. The rubber piece did not disconnect when I jacked the car and there is no separation below the rubber-to-metal o-ring seal.
It appears that the strut can be swapped without disconnecting the upper control arm. Can some one please tell me if that is the case. Thank you very much.
To answer your question, yes you can swap without removing the upper control arm. I found this out the hard way when I forgot to swing by autozone and rent a ball joint remover. we got the old strut out easy (because it was collapsed) and began scratching our heads how we could get the new one in. I got the idea to take the little plug that arnott installs in the new strut at the air fitting out, and let the shock bleed out the air and shrink up. It takes about a hour or so. After that,we laid it next to the old busted shock and bam, same size. The new shock slipped right in.
When you reconnect the battery after the installation and start the car for the first time, you'll probably get an Airmatic, BAS, ESP, etc warnings going crazy on the dash. To reset, turn the wheel all the way full lock to the left, then all the way full lock to the right. It will reset the system and you'll be good to go. These instructions are also in the owners manual, I think under the ESP system.
Cheers! It's not a hard job at all!
