Stop Car too low in red
1. Check/search the forum and you will find A LOT of information about that issue. It's very common problem with all w220 with airmatic - they all fail sooner or later.
2. Your airpump has failed and/or your struts front/rear have failed as well. Airpump has to be replaced. Struts you might be able to seal with a special kit from MB or you may need to replace them as well.
3. You looking at about $2000-$3000 work at your local MB Stealership
These struts aren't cheap either. I'm thinking about doing a coil spring conversion, but don't know much about them. Hoping someone can help me out on that one...
I am a strong advocate of keeping a Mercedes original, so I favor replacing the struts. Arnott uses better seals and much stronger air bags; around $800 each for new, $400 for rebuilt.
Few people (as of this date) have replaced with coil springs, but a search may yield their results.
