Windows & Sun Roof Opening
Old Jul 17, 2011 | 10:34 AM
LAL's Avatar
LAL
2000 S500
I have looked for the answer and can't find unless i missed it. When unlocking car and holding the unlock button on key all the windows and the sun roof use to all open at once. I tried it the other day and it no longer will work. I tried new batteries in key still nothing , anyone know what it might be. It is a nice option on a very hot Day here in South Florida. Any help would be appreciated...Thanks
Old Jul 18, 2011 | 03:47 PM
FrankBoni's Avatar
2005 S500 4 Matic
you have to reset it. ignition on, ac on auto, then hold the center button on the controller, not the left or right fan adustment. Press and hold the center button for a few. Shoudl work.
Old Jul 20, 2011 | 08:55 AM
LAL's Avatar
LAL
2000 S500
Tried it and it did not work. Does it make any difference that the center bar is the fan control and the 2 side bars are the temp controls for either side.
Old Jul 20, 2011 | 02:14 PM
Delux2d's Avatar
00 S430 & 02 Suzuki 750 Katana
yes so did I.. I tried it and it didnt work I have a 2000 S430. Does the feature work with my year and model.
Old Jul 20, 2011 | 05:02 PM
stevedel's Avatar
W220
try both the driver and passenger sides. if it works on one side, you likely have a bad IR receiver.
Old Jul 23, 2011 | 03:06 AM
AH1W-COBRA's Avatar
2003 S500, 03 C240, 03 E320, 03 tahoe
ditto on the ir receiver
MB replaced mine on both doors, cant remember what it cost.
Old Jul 25, 2011 | 10:29 AM
LAL's Avatar
LAL
2000 S500
Can you have a bad IR and the key still works unlocking the doors?
Old Jul 25, 2011 | 11:50 AM
stevedel's Avatar
W220
yes, IIRC the door locks work via RF and the windows use IR. i had my driver side replaced before at the dealer under warranty and it included a new door handle & paint. i assume the fix would not be as cheap as one would think. are you pointing your key at the IR receiver when you try to open your windows?
Old Jul 25, 2011 | 01:11 PM
pjkwong's Avatar
S500
i had the dealer fix my sensor on my driver said door handle to work when i first got the car.
