Trunk Lid Open-Assist Problem
In all cases the hydraulic pump on the right, directly next to the battery, makes no sound. Bad hydraulic pump? Doubtful, as a voltmeter confirms there is no power whatsoever going to the hydraulic pump when the red ‘trunk close’ button is depressed. If I press the ‘trunk open’ button on the remote key, the PSE pump comes to life and unlatches the lock, but the hydraulic pump fails to energize. This is what I think is unique about this problem.
So we look for blown fuses. The Fuse Chart indicates 3 fuses of interest – F13, F57, F62. On the sheet these are listed under “Remote closing and locking trunk lid” and “Remote trunk lid release”. All 3 fuses ohm out correctly. To my thinking, there must be some sort of relay that controls the direction of the hydraulic pump rotation as the hydraulic pump motor only has 2 wires (black and white), suggesting a bi-directional motor. However, the fuse chart does not list any relays associated with the trunk. So I have a couple questions:
1) Is there another mystery fuse somewhere that controls the trunk lid opening/closing hydraulic pump (not the PSE Pump)? Fusible link, maybe?
2) Where are the directional control relay(s) for the trunk lid opening hydraulic pump? There are two small relays very near the pump’s electrical connection, but it’s unclear if these are related to the trunk lid open/close pump.
I doubt it’s the infamous trunk lid latch actuator since this has (to my knowledge) no effect on energizing the trunk lid assist hydraulic pump. Any ideas?
Cheers,
Jeff
Cheers,
Jeff
The fix was simple; connect to STAR and reinitialize the PSE circuit. Interestingly, the trick of holding down the remote trunk open/close switch in the driver's door does for 5 seconds does not work with the newly rev PSE Pump! Reinitialization is the only fix. BTW, the local dealer reinitialized the system for me at no charge.
Cheers,
Jeff
Cheers,
Jeff
Cheers,
Jeff
"Dear Mr. Perez:
Since 220 800 11 48 is no longer available 220 800 12 48 is approved by Mercedes-Benz as a replacement for the prior part on any repairs the prior part would be required.
We apologize for any confusion and recommend you speak to the parts department at your local authorized Mercedes-Benz dealer if you are still uncertain about the part.
Maria"
i have 2002 S500 with "Designo" Package.
"MERCEDES S500 Vacuum Supply Pump For Remote TrunkLocking Pull down see pic attached)
I need to know how you can open the lid (I just call it) andput fuel (my understanding it should be light hydraulic oil), I did open thesteel strap and till can’t pull out lid
Cheers,
Jeff
