License Plate Light Lamp not working DIY wiring repair
One snag you will run in to when diagnosing is that no power will be sent to the plate lamps unless the trunk is closed. I'm sure there is a way around this, i locked the latch and grounded it but that didn't work. Anyways with some of the panels you have to take off to get the lamp sockets out you will have holes to run your test leads through to pin the wire in different areas.
Other than checking fuse. Check for power at the lamp socket. With no power at the lamp move on.
Find the wire your looking for in my case it was the only one twisted together with the power wire to the other socket, check for power on your wire at the Rear SAM
I had power on my wire at the rear sam, so next I probed various spots along the loom and narrowed it down to this 1 foot section of wire. I was lucky enough to see 1 copper strand sticking out of the braid.
After I cut some of the braided loom open I found my wire stretched and broken along with the power wire to my other license plate lamp broken but still touching.
http://www.benzworld.org/forums/w220...t-working.html
I, too, have the same problem with my left side license plate light not working but the bulb is good, I read CarBizIndio's post and thinking that must be it but being lazy I have not yet open any panels or braided wire loom in the trunk.
Mike
