Front End Squeak????
Old Feb 11, 2012 | 05:20 PM
mbztlc9's Avatar
2002 S430
Need some advice trouble shooting front end squeaking. The problem went away a few months ago after an oil change. It started up again today, after another oil change again....I do not hear it squeaking???
Old Feb 12, 2012 | 08:51 AM
Quadcammer's Avatar
96 and 08 911 turbos
you're going to have to be more specific.
Is it from the engine, the suspension, the belt, etc?
going to have to narrow that down before anyone can help you farther.
Old Feb 13, 2012 | 01:36 AM
S600Keith's Avatar
S600
Must be the upper control sway arm antifreeze connection.
But seriously, there must be in the neighborhood of 50 things it could be. Did you honestly expect to be able to post up a question about squeeking on a bulletin board and get a diagnosis?
Keith
Old Feb 13, 2012 | 07:54 AM
DRTYLNDY's Avatar
Here is my guess from what you have told us.
I think it is the lower ball joints. When they get worn out the front end creeks and makes a funny noise. When you get the oil changed do you know if they lifted the car? If so when the wheels left the ground it may reposition the ball joints so they either creek or not. All because they are worn out. If you spray WD40 in there and on the rubber bushings the noise should go away for a short period of time.
Again this is my guess from the little info we have to go with.
Good luck
Johan
Old Feb 13, 2012 | 07:30 PM
mbztlc9's Avatar
2002 S430
The noise is definetly coming from suspension components. My guess...it is bushing/control arm related. However, the oil change threw me off a bit.
From a repair cost standpoint, what should I expect to pay for either a control arm and/or bushing replacement? Could a dry bushing cause the problem and a little "grease" fix it long term?
Also, could upsizing wheels/tires cause a suspension issue like this? I put 19 in. wheels on it 8.5 Front/9.5 Rear- Michelins
I don't want to spend $2K for something that could be fixed with WD-40.
Thanks in advance fellas!
Old Feb 13, 2012 | 08:29 PM
DRTYLNDY's Avatar
If it is suspension related the WD-40 will only silence it for the short term. You still need to get it fixed really.
Old Feb 14, 2012 | 10:40 AM
haoz129's Avatar
MB 2003 S600. Volvo 2003 XC70.
+1 with Johan.
If problem is from part of the suspension you need locate and fix it asap.
Driving such a heavy car with loose suspension part is dangerous.
Imagine it gives up during a highway cruise, result could be catastrophic.
Take care.
Howard
Old Feb 16, 2012 | 02:20 PM
aasim305's Avatar
2003 s430
Check your lower control arms. I had the same issue and turned out to be my lower control arms.
