19" AMG style wheels $699 *NEW* from PowerWheels Pro
Former Vendor of MBWorld
WHEEL SPECIFICATIONS
Offset: 35mm
Weight: ~27lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: Gun Machined Face
Shipping: $85
Price: $699/set
SLS Style
SLR Style:
SL65 Style:
AMG Type V
W211 E63
W204 C63:
2012 CL63:
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards. Obvious exclusion is curbing, denting or any other misuse that can damage or etch the finish such as use of strong chemicals in the cleaning process.
Manufacturing Defect Warranty: The wheels are made utilizing the low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
PURCHASING
You are welcome to purchase the wheels from our website at www.powerwheelspro.com or you can call your order in at 248 686 2035 or we can send you a paypal invoice.
Thanks for looking!
I don't want to knock a fellow sponsor, but selling fake AMG wheels with the AMG logo stamped into the wheels can't be legal or approved by MBWorld, can it?
It just seems WAY over the top.
Bruce
Bruce
Tuscan1311, thanks for the inquiry, did you want 18s, 19s or 20s?
We can also do tire packages as well, let me know if you would like any quotes on that. Not sure if you are looking to keep your existing tires.
Thanks,
Thanks,
2006 E55 AMG, Alfa Romeo Stelvio Ti Sport
I am looking for the AMG style 846 that you have available in your website but in gunmetal finish rather than black. My car is a 2006 e55 silver, so I think that would work bettter. Also, regarding the offset would 40mm work if my car is lowered (via lowering module) and I want to run at least a 275/35 wheel at the back?
On a side note, what's the duravility of these wheel and are they warranted for cracks just as they are warranted for the finish?
Hi there,
Unfortunately those 846 style wheels are only available in black at this point in time. We do have a couple of gun metal with machined face options that would work on your E55.
Your AMG brakes do require a 35mm offset or lower though, otherwise the back of the spoke will hit the caliper in the front. Nothing a thin 5mm spacer wouldn't fix though.
Regarding durability, our wheels exceed all international manufacturing standards as they are made in an OEM factory using the exact same manufacturing process as OEM wheels, low pressure casting (for non forged wheels)
There's no warranty for cracked wheels, not even on the factory wheels, but as long as you live in a state with reasonably good roads, you shouldn't have any issues running 19" wheels.
Hi there,
