Battery died, charged - intermittent malfunctions
I had several malfunctions - SRS, Presafe inactive, and SRS failure.
Brought the car to the mechanic who fixed the shift lock (ordered 2 aluminum "claws" that didn't fit, ultimately used a plastic one - total cost parts and labor $550). I haven't spoken with him about the malfunctions as I was traveling - he said he would take care of it. My wife picked the car up - drove it once or twice over the 2 weeks I was away, and said it was fine.
Yesterday morning I started the car and all 3 malfunctions are back. Warmed the car up, turned it off and restated - they are still there. Drove about 10-15 minutes, turned the car off - no change. Drove another 5 minutes - turned the car off, and went into the store for 5 minutes - when I restated the car, the malfunctions are gone.
Drove the car the rest of the day running errands with no issues.
Since I originally had the error messages, and I believe the mechanic reset them (my wife would have noticed if there were any issues) - and then they returned yesterday, I am concerned about an intermittent problem - possibly something caused by charging the battery with it still connect?
Anyone seen this before - or offer any advice if I should be worried or ?
Thanks in advance,
B
Took the car out this morning - back and forth to the store - no malfunctions. Left the house this afternoon - this time had the ABC error. Stopped at the 7-11 1/4 mile from my house for coffee. When I came out - no malfunctions. Drove the car 40 miles to Brooklyn without issue, and after a few hours - took it back home with no issues.
Again, the malfunctions seem to be intermittent. Does this still sound like a low-voltage issue related to the battery? If so - I'm hoping it got a good charge on the 80 miles I drove it today...
Thanks,
B
The ABC code maybe unrelated. You can check the voltage I believe through your climate control. After mine went flat I put it on a trickle charger for 48 hours to get a deep charge. Didn't have any issues with it.
Check your voltages to be sure you are up to spec.
