temp sensor, horn broken
Old Jun 26, 2003 | 02:44 AM
jjrho's Avatar
2001 s500
hi, have a 01 s500S with 33K....
in noticed the outside temp. showing 119deg. when was only 102. . . . , are there known problems with this issue?
also, my horn is on monotone now.... one's broken i guess.... should be a warranty cover.....?
exhaust is hitting /vibrating in the back recenty. . . .
o/w, is there anyway to have a daytime running lights to come on in the s class?
j.rho
jjrho@adelphia.net
Old Jun 26, 2003 | 02:53 AM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Things like you mentioned should be covered by warrantee. I believe it's 4/50000 plan. So, yours shouldn't expire until 2005.
Old Jun 26, 2003 | 11:54 AM
jutch's Avatar
MB s430
Has is your air conidtioning working at that temperature?
Old Jun 26, 2003 | 03:06 PM
apricotscrub's Avatar
mine went too, the temp said like 100 degrees but it was like 50 outside.
15$ replacement sensor, its in your left grille under the bumper, its a small sensor, once its replaced, it'll be fine.
Old Jun 26, 2003 | 09:38 PM
ano0oj's Avatar
09' 335i coupe
were u driving the car when the temp showed 119?, cuz if ur in place and just started the car, the temp. is usually higher than the real thing.
ano0oj
Old Jun 26, 2003 | 10:29 PM
shaggy982's Avatar
2000 Mercedes S500
you can set the lights to daylight running lights. it could be done by the controls from the steering wheel (i'm almost positive). otherwise check the manual.
Old Jun 27, 2003 | 04:03 AM
jjrho's Avatar
2001 s500
reply to above Qs
hi, thanks for your responses....
we were driving the car when the temp. went erratic....
The day time running light - i followed instructions for 'constant ON' mode and it turned the xenons on but also all the parking lights around the car....
Is there a way to turn on ONLY the front halogens or xenon? like a true DRL system?
the A/C seems to be ok but it's not as cold as i'd like....
we had a leak and it was fixed and recharged....
j.rho
Old Jun 27, 2003 | 04:12 AM
mercsd's Avatar
Porsche Carrera 2008
a/c cooling
j.rho
Keep the center thumb wheel on blue and not on auto for max. cooling.
Old Jun 28, 2003 | 08:31 PM
ElDiabloJoe's Avatar
'03 W211 aka E-500
Re: a/c cooling
MercSD,
Your .sig states you have a 2003 S 350?
I thought they were only available in 430 and 500 versions?
EDJ
Old Jun 29, 2003 | 12:36 AM
vraa's Avatar
Re: Re: a/c cooling
Originally posted by ElDiabloJoe
MercSD,
EDJ
Outside USA i believe.
Old Jun 30, 2003 | 01:26 AM
mercsd's Avatar
Re: Re: a/c cooling
MercSD,
EDJ
Yipe,
I've got a S350 (3700 cc, V6, 245 bhp) the 0-62mph is 7.3 which I think is same as the 430. Here's a link to my dealer's web site if you need more info:
http://www.gargash.mercedes-benz.com/frame-pc.htm
Old Jun 30, 2003 | 01:38 AM
mercsd's Avatar
Re: Re: Re: a/c cooling
Greetings from Dubai UAE
Old Jul 3, 2003 | 03:26 AM
jjrho's Avatar
2001 s500
dealer work on above problem
so far, i have a broken horn - fixed easily.
the temp. sensor had 'fallen out of where it should be'....
now, the new one is:
i told em abt noise from under the car/exhaust system rattling a bit on idel.... and they found a bad catalytic converter.... and are changing it ! what gives??? i had no indications as to that....
j.rho
01 s500S
