Is it ok to leave the car idling and not driven for few days?
sorry, should have termed it "is it ok to leave the car sitting in one place for few days without it been used?" rather. What you were confused about is definitely not what I meant
.C280 sport,
Thanks for the reply and advice. I do start the car and let it sit for a few mins once a week or so. But apart from the battery, anything else that would be affected as a result of car sitting in one place for a long period of time? Since my W220 is equipped with airmatic suspension, I was told that to increase the suspension's life, car should be driven often. I just want to reassure that from an expert? Dont want my suspension to die on me relatively earlier as its supposed due to my negligence. One airmatic unit costs about $1100 here.
Your best bet is to get a trickle charger and drive it when you need to.
.C280 sport,
Drive it once a week, get it up to operating temperature and put it back. If that's not a possibility, leave it on a trickle charger and only start it when you plan to drive it. If it sits for a long time, put in fuel stabilizer.
Unless you fancy replacing engines. Unless you are going to drive it, don't idle it.
I left my car sitting for 3 weeks with the battery connected back in 2010, came back and it started like a champ.
A month later though is when my battery drain issues started...related or unrelated? who knows.
Machines... do not like to SIT. They are built to be used.
Kidding aside (sort of?), agreed w/ others - don't just start it, drive it up to temp and get it WOT at least once before you park it. You know, the 'ole Eyetalian Tuneup.
Works wonders!
I'll never understand those who buy such marvels only to park them to gawk upon static.
Make 'life' your extravagant event 8-)...
but when you leave your precious Airmatic will fail sooner than usual.
i did your trick before, and my airmatic fails within 2 years.
so i have replaced my airmatic suspensions, and leave the trick alone.
i took my car
just around the house just took like 5 mins when i dont use it.and it has almost 5 years and the airmatic doesnt fail.
cmiiw.
i took my car
cmiiw.
