Opening Windows With your FOB..
Garage Temporarily Empty
Is it correct that our cars have the feature to open windows and sunroof by holding down the unlock button on the FOB while pointing at the driver's side door handle?
If so, how can I reset/resync it? I cannot get this feature to work.
-Chris
-Chris
At least with my 04 E500, the fob needs to be in relatively close proximity (within a few feet), unlike a Maxima that I owned where you could perform the same feature from 30-ft. I think it's referenced in the manual as the Summertime feature.
W220
not sure if it may have changed on later models, but I have to aim my key at the IR receivers on my front door handles. If that hasn't worked for you, your receivers could be bad.
Thanks.
S500 4 matic
I use the feature on my s500 it works when it wants to. You have to be atleast2-3 ft from receive to operate. To sync windows turn car on and put key to on position. Them press the down button on driver side door holding it down till it stops and wait 5 secs you will hear a click then do same on way up position wait for click then release. Thats it for sun roof push switch back to open sun roof hold it back for 10 sec then clise it ush seitch forward hold 10 secs and thats it. It worked for me. Just that it has a mind of it own when u want it to work it does not but just mess with it it works fine. Good luck let me know how it goes.
Location: Saratoga Springs, New York & Sarasota, Florida.
MB’s
Yes a 05 S600 will have it. Hell my 05 C240 even has it. Sounds like the receivers went bad or you could try replacing the fob batteries. You can pick them up at Radio Shack or a CVS.
k i thought id ask in hopes someone might know or reveal the procedure..
possible to summer close/open front left/right window and sunroof only?? (excluding rear windows)
thanks!
thanks!
I've never heard of a procedure to open only select windows/sunroof.....
