passenger mirror dip-down in Reverse - not working
Old May 4, 2012 | 11:55 AM
Sgt. Schultz's Avatar
opposite-lock...
Soas to fully display my ignoramus this morning, I figured I'd toss another motzaball of a stoooopid Q out here for your general bemusement.
I cannot for the life of me get the passenger mirror to program to dip down during Reverse. LOVE that feature.
RTFM (read the friggin manual), did the programming procedure - nothing.
STOOPID MB... Audi, you simply leave the mirror selector in the "passenger" side and that feature was activated. Granted, you couldn't 'tailor' the tilt but who cares!? Least it worked 8-/.
Anyone care to shed some insight on my ineptitude (er, 'this' ineptitiude, not general - you wouldn't have enough time / energy)?...
Old May 6, 2012 | 11:10 AM
chpsk8's Avatar
2003 S430 2008 GL450
Do you have the auto dip feature turned on in the menu?
When you programmed it, did the mirror move when you hit the M button?
Old May 6, 2012 | 02:55 PM
stevedel's Avatar
W220
Make sure the passenger side mirror is selected as if you were to adjust it.
Old May 6, 2012 | 06:14 PM
classyS's Avatar
2001 S430
stupid computers.
Old May 7, 2012 | 10:13 AM
opposite-lock...
Hmmm, I've only seen in the menu the choice to have the mirrors fold - not dip. You sure about that? Manual references the programming procedure.
the mirror did not move when I hit "M"
And yes Steve, I do have the passenger mirror selected - silly.
Old May 9, 2012 | 08:25 PM
trombone's Avatar
2002 S430
Geez!
I am the ignoramus Paul, not you, I thought my right mirror had a crazy malfunction!
Of course I blame the manual, it is a nuisance to page forward/backward endlessly.
I hope you find the solution soon.
George
Old Jun 7, 2012 | 05:56 PM
paranoidpants's Avatar
Evo VIII
did anyone figure this out? i've read the manual and carefully implemented suggested procedures. no dice.
Old Jun 10, 2012 | 06:19 PM
fisherman123's Avatar
04 S600 16 Honda
Try this Sgt.
This is how I did it when I first bought the car, only two steps: Turn On the rear mirror parking feature and Storing,programing the mirror position.
Turn on the feature
1) Ignition On, car in park, doors closed.
2) Use steering wheel menu control buttons go to setting, use a combination of up,down and +,- buttons to go to convenience submenu(here you can also setup easy entry/exit,auto fold in exterior rear mirrors,key dependency,etc.....) use +,- buttons to select(turn On or Off)mirror parking feature.
Storing mirror position
1) Press down passenger-side rear view mirror button
2) Use the 4 way adjustment switch on driver's door to adjust passenger-side mirror in and down a little or any position you feel comfortable with so that you can see the rear fender and the curb when parking in reverse.
3) Press memory button M
4) Very Important, Within 3 seconds, press the Down Arrow on the 4 way adjustment switch as if you want to adjust the mirror down.
5) The parking position is stored if the mirror does not move down.
6) If the mirror does move down, repeat steps 1to 4
To activate and confirm it's working properly
1) Ignition on,press passenger-side mirror button down,mirror dips when shift into reverse.
2) Drive faster than 5 mph, it should return to it's preset driving position
3) Press driver side mirror button will return to it's original preset driving position immediately.
4) Eight to twelve seconds after shifter is out of the Reverse will return mirror back to it's preset.
***** NOTE *****
I am sorry I only have one key so I don't know or can't say when a second driver or second smart key is used will get the same result.
Mike
Old Jun 11, 2012 | 02:37 PM
opposite-lock...
Thanks Mike - I just tried this - a few times...
...totally didn't work
_W_T_F_?
I'm stupefied (and a bit stupid, as well)!
Old Jun 11, 2012 | 09:14 PM
04 S600 16 Honda
Don't feel bad Sgt, It took me like seven attempts in two days to get it to work also.
What steps,area did you have problem with?
Old Jun 12, 2012 | 09:58 AM
opposite-lock...
thanks Mike
well, my "convenience" menu in the dash display DOES NOT contain "mirror parking" feature - only fold mirrors and easy access (steering wheel / seat)... that is IT
seems my problem lies there
what up wit dat???
Old Jun 12, 2012 | 01:36 PM
04 S600 16 Honda
Mmmmmm, Strange, I thought all our 220 has this feature? anyway I just double checked the steps on my 04 and sitting inside the car as I type.
Let's try it again. Go to setting....
use up button, I saw the screen shows Inst. Clus, Lighting, Vehicle, Convenience.-------->move +,- down to select Convenience,
Press up button----->setting key-Dependent
Press up-------------->easy-entry
Press up-------------->Mirror Setting when Parking.(Strange you don't have this)
Press up-------------->Fold in when parking
Press up-------------->Settings Reset with R-Button for 3 Sec.
Press up-------------->Goes back to setting and cycles around.
Sgt. you said you only have Fold Mirror and Easy-Entry but how about Key-Dependent? two out of four? How about try to hit the Up button repeatedly, let it cycle through the menu a few times
I am having issue with Tire Pressure Warning not displayed on the screen myself and sitting here playing with it, Good luck. talk later.
Mike
Old Jun 12, 2012 | 02:01 PM
opposite-lock...
exactly Mike - I have 2 of those 4 - also do not have "key dependent"
I've tried every combo of scrolling imaginable 8-/
makes no sense
Old Jun 27, 2012 | 10:43 AM
GasPrice's Avatar
2006 S500 4M; 1996 E320 Cabriolet
The mirror dip and multiple key identification option does not exist on some 220s. Mine (2006) does not have it show up in the instrument cluster, therefore you can't even turn on the mirror dip function. Yes, it's in the manual, but no, that menu item is not there.
I've read here in some very old threads that adding that function back into the cluster is done by 'recoding the instrument cluster'. I don't really know what that is, and neither did anyone else.
Neither my independant or the dealer could figure it out. The official response from HQ was that 'this feature was discontinued' for the 06 model year. Although that does not make any sense, so it is.
Old Aug 7, 2013 | 10:47 PM
Edlewis11's Avatar
2006 s600
Mirror dip feature
I can confirm it does exist in the 06 s600. I recently purchased one and when I first bought it that feature was working. I reset the features and haven't been able to get it to work since. Anyone find any working solutions.
Old Aug 8, 2013 | 09:30 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
When you want to use this feature there is a button on the driver's side door that controls the manual movement of both mirrors (left to right, up and down).
I had the same problem you are having but discovered that in order for this feature to work properly the button for the passenger side mirror must be pushed in prior to the car being put in reverse. If the driver's side mirror button is pushed in the reverse feature will not work.
All of this info is assuming that you have the feature pre-programmed via dash display.
Old Aug 8, 2013 | 10:25 PM
Edlewis11's Avatar
2006 s600
It works. Thanks ibeforreal. I don't have the option in the dash display but it still worked.
Old Aug 8, 2013 | 10:58 PM
ibeforreal's Avatar
Glad it worked out for you.
Old Aug 9, 2013 | 10:34 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
I believe there is something to this!
My S600 does NOT offer any options other than " mirror fold when in park", but that function does does not work automatically, only when selected on the door panel.
Other function like easy entry works when selecting on the stalk.
I think the culprit here is that on my car the instrument cluster was replaced under the warranty campaign (before I got the car), and was not recoded or programmed correctly, or, programmed incompletely.
Old Aug 10, 2013 | 08:55 AM
wallyp's Avatar
2003 S500 2007 GL450
My friend's 2002 S430 does not have the mirror dipping option on the "convenience" menu - but the mirror dips in reverse. This irritates his wife when she reverses into the garage, so we will try pushing the button selecting the driver's mirror to see if that stops the dipping. My 2003 S430 does have the mirror option on the menu.
Old Aug 10, 2013 | 10:35 AM
ibeforreal's Avatar
The option also bothered me Wallyp because I always back into my garage. That is how I kind of discovered how the thing works. However, when I am backing into a parking space it is quite handy. Should work for you friend's wife also.
Old Aug 10, 2013 | 01:57 PM
wallyp's Avatar
I accidentally have the best of both worlds. Apparently, the switch on the gearshift lever is very slightly maladjusted, and when I put the lever in Reverse, the backup lights don't come on, and the mirror doesn't dip. This is good for almost all of my day-time driving. When I want the lights or the mirror dip, moving the lever 1/16" further gives me both.
Old Dec 7, 2013 | 05:03 PM
bhoffman1us's Avatar
Mercedes Benz GL 450 2007
Thank you. I couldn't figure it out
